Integrating ethercat with QTplasmaC and Beckhoff modules
- GFC
- Thank you received: 6
26 Jul 2026 11:31 #348075
by GFC
Integrating ethercat with QTplasmaC and Beckhoff modules was created by GFC
Over the last year I have been building a gantry plasma table with leadshine el8 servos and Beckhoff modules for I/O, I struggle a lot with software but with help from rodw over on the ethercat forum and some guides I managed to get ethercat working and a basic QTplasmaC config.
but im still having some troubles:
I managed to get these things working:
-QtPlasmaC interface
-motion on all axis when jogging the machine
-external E-stop
-torch break detection switch
-machine enable output turning on a light
what isnt working:
- cant get a torch on output signal when I do a torch pulse
- the ohmic probe enable doesn't output any signal
-when I hit cycle start the G code pauses without moving the machine
I have a EK1100 coupler, an EL1008 digital input, an EL2008 digital output and EL3102 analog input to read the divided arc voltage.
what are the best ways to debug this situation and what should I be looking for?
all config files in a zip file below
previous post:
forum.linuxcnc.org/ethercat/59024-integr...khoff-modules#348066
Thank you all for your help
-external E-stop
what isnt working:
previous post:
- GFC
29 Jul 2026 07:53 - 29 Jul 2026 07:54 #348168
by GFC
Replied by GFC on topic Integrating ethercat with QTplasmaC and Beckhoff modules
I have been tinkering withit and managed to get the touch probe to work,
what I think its happening is that QTplasmaC doesent want to run any Gcode or any of the user buttons, because the borders of the windows just turn white I click a button or hit cycle start
is it possible for the machine to jog correctly but not run Gcode?
what could be causing this?
Last edit: 29 Jul 2026 07:54 by GFC.
- GFC
15 Aug 2026 11:33 #348774
by GFC
managed to fix this by completely rebuilding the config, no idea what was causing it
