THC doesent work when G code is running
18 Aug 2026 12:24 #348837 by rodw
Replied by rodw on topic THC doesent work when G code is running
have you chosen the correct mode in plasmac? refer docs
18 Aug 2026 14:17 #348839 by PCW
Replied by PCW on topic THC doesent work when G code is running
Sorry I missed the analog stuff in the hal file.
One thing you might do is (with LinuxCNC running)
1. Without gcode running:
halcmd show pin plasmac  > nogcode.txt
2. With gcode running:
halcmd show pin plasmac  > gcode.txt
and then compare the two files.
18 Aug 2026 14:20 #348840 by NWE
Replied by NWE on topic THC doesent work when G code is running
Is it performing the touch-off and arc lighting when you start the program? Torch goes down, contacts the plate (depending on your touch-off sensor), goes back up to striking height, lights the arc, at which point the THC can start reading arc voltage. Is it doing any of that?
18 Aug 2026 19:55 #348844 by GFC
Replied by GFC on topic THC doesent work when G code is running
after checking I in fact had the mode set to zero when should have been set to one, must have messed with it when I was testing, changing it to the correct mode did not affect the problem
the torch is performing touch off and arc start correctly, just the thc after not activating
I did run the codes to create the txt files but dont know how to do the manual cut and run the halcm at the same time, so thc wasnt active then, cant see anything different in the files but i dont really know what im looking at
both files below
18 Aug 2026 21:16 #348845 by rodw
the only thing I could see was  36 bit IN FALSE plasmac.thc-auto <== plasmac:thc-auto
I would have thought you would have this true in the GUI. Does it change the pin if you do change the gui setting?
plasmac:thc-auto should be set in a system file though
19 Aug 2026 21:04 #348865 by GFC
I just checked, the Gui button changes the pin, but isnt affecting the thc activation
22 Aug 2026 09:58 #348909 by GFC
Does anyone know a full list of requirements for thc activation so I can check them one by one?
