Are you using the THC to follow the contour of square tubing or from gcode output of sheetcam driving Z axis without THC?
Did some experimenting a while back with a fast Z axis and a Prima THC, it did work quite good, but noticed that on the way down the torch would lag a bit meaning to high from the tube, but the cut was OK. This was with max. 50X50mm square tubing, did not need more so did not try but I doubt it would work as the slope becomes to much for the THC to follow. Also this was with only one moving axis, so the torch was moving only in one axis and Z height.
I am aware that having both axis X and Y moving and using a post processor is much better and can cut any size the machine can handle, but I did not have the post processor and lacked time.
Thanks for the info.
BTW, the last rotary I built had only probing with no THC as it was only for round tubing. Ended up pretty cheap and the client is extremely happy with it. Also looked nicer than the rest of my machines. I did post pictures and videos here I think.......or did I???
ASUS ROG Crosshair VIII Impact - AMD X570
