Powermill LinuxCNC Post
- bbsr_5a
- Thank you received: 106
25 Jan 2020 16:32 #155732
by bbsr_5a
Powermill LinuxCNC Post was created by bbsr_5a
Hi
we got a Education Center Powermill Licence
but there is no Postprocessor include in the Licensing
does anyone know a Guide fo setting up a Postprocessor
the Edit tool is included and 3D XYZ workes fine a 4th (5th) axis wounded be great gift
- aleksamc
- Thank you received: 67
28 Jan 2020 18:25 #156034
by aleksamc
Replied by aleksamc on topic Powermill LinuxCNC Post
Hello, I had some experiance with creating postrpocessor for 5 axis PowerMill 2017 a year ago.
I worked in such way:
I found default postprocessor for 5 axis in internet and changed it correspondly to my porposes.
As for now I don't have such Posts because I'm in business trip and not near my PC.
- aleksamc
28 Jan 2020 18:26 #156035
by aleksamc
I suppose that PowerMill developers should help you to creat post for your machine if you buy this program
- bbsr_5a
30 Jan 2020 08:02 #156151
by bbsr_5a
Replied by bbsr_5a on topic Powermill LinuxCNC Post
if possibel can you share your post here to get it modyfied as the editor is on the system it shoudt not be that hard to get to it
woudt be a great advanced to the Education center to get a Running 5Axis CAD/CAM/CNC system
Thank You
Thank You
- aleksamc
30 Jan 2020 09:06 #156153
by aleksamc
Now I haven't such possibility because I'm in buisiness trip. An I will be here aprox. a month.
As I said, I found 5-axis post in internet.
But before you start to change your post, you need to make your virtual cnc machine for PowerMill. PostProc takes all needed information from this machine to work.
- bbsr_5a
30 Jan 2020 11:51 #156169
by bbsr_5a
i got Time until Feb 2021 so time is no Factor to learn how to do and setup the Virtuell machine
i need a start point where to put the STL files of the Machine parts and position them
if possible can you write a rundown
- aleksamc
30 Jan 2020 20:04 #156199
by aleksamc
What exactly do you need to write?
1) You need to make virtual model of your cnc machine and to adjust all axes.
2) You need to import (connect) your model to postprocessor and to modify post for your special cases.
Then your can work with it and to make G-codes.
Posts for mach3 also suitable.
- bbsr_5a
31 Jan 2020 07:39 #156235
by bbsr_5a
this is Clear to me
But where is the File that holds the Connection to the Virtual STL files
i did not find any Machine in the Installation of Powermill
This is my Problem I got all Axis connected Parts Separated and Downgrated to get a Sharp clear
Machine Model
i did add the STL files here
if i setup a machine / RENAME from a Example it ads about 100files pmlet and a MDdata folder
there is a File that seams to hold the geometry as a XML but no guide or info on how this is syntaxed
THANK you for your help
If there where a Example im shure i coudt do it
and safe the School lots of money as they fine 1kEUR Post costs
Machine Model
- aleksamc
31 Jan 2020 19:11 #156268
by aleksamc
From your last messege I understood that you are know nothing about PowerMill post processors and their machines.
Also I know nothing about your problem and your machine, except that you need 5axis post.
Try to read PowerMill documentation to understend right way:
MTD user guide
Build Robot simulation in Powermill
PS
PowerMill doesn't work with stl-files, only *.dmt
MTD user guide
PS
- bbsr_5a
04 Feb 2020 13:28 #156501
by bbsr_5a
Thank you Sir i will make DMT right away and start reading the guide
Time to create page: 0.259 seconds
