Another GUI project underway
7 years 3 weeks ago #147479 by Lcvette
not sure but there have been some major changes to the repository of probe basic recently so it may have to do with that
i am writing a new installation doc that should be good for the new repo locations for development, i will post those once they are tested out some more.. would love the help!
The following user(s) said Thank You: ssd
7 years 3 weeks ago #147480 by Lcvette
not sure, but currently the only size is 1080x1920.. not sur ewhat it would look like on a higher res screen, but you could try it out and see?
The following user(s) said Thank You: tommylight, ssd
7 years 3 weeks ago - 7 years 3 weeks ago #147489 by ssd
Replied by ssd on topic Another GUI project underway
Lcvette wrote: not sure, but currently the only size is 1080x1920.. not sur ewhat it would look like on a higher res screen, but you could try it out and see?
I will indeed set up a computer and test the GUI tomorrow. I wasn't aware that it is already included with QtPyVCP.
Last edit: 7 years 3 weeks ago by ssd.
7 years 3 weeks ago #147584 by vmihalca
I have tried editing the probe_basic.ui file on my linuxpc, changed a few dimensions, saved the file but when I ran the probe_basic UI again, there were no changes.
I am trying to do some changes on this UI, I wanna make it fit on a 15 inch wide touch screen that's 1376 * 768 or smth like this.
I know I will have to re'arrange the components but first I would like to see the changes.
Please advice! :)
7 years 3 weeks ago #147590 by Leon82
Replied by Leon82 on topic Another GUI project underway
vmihalca wrote: I have tried editing the probe_basic.ui file on my linuxpc, changed a few dimensions, saved the file but when I ran the probe_basic UI again, there were no changes.
Please advice! :)
You can try to set the main window max size. But you also need to check the minimum size as well as it could be bigger than your new max size
6 years 11 months ago - 6 years 11 months ago #150301 by gantarone
is there a way like in Gmocappy to select a drawing and have the corresponding gcode selection? :huh:
Last edit: 6 years 11 months ago by gantarone.
The following user(s) said Thank You: Lcvette
Moderators: KCJ, Lcvette
Time to create page: 0.410 seconds
