Another GUI project underway
7 years 4 weeks ago #146933 by ihavenofish
my screen is 2048 x 1536, 10". apple ipad display.
i will have no mouse on the machine.
7 years 4 weeks ago - 7 years 4 weeks ago #147127 by vmihalca
I would need some help with editing the UI.
I have opened in the QT designer the probe_basic.ui file.
I have changed the width of gcode editor, along with the elements that were wrapping it. I tried to see if my changes are taken into account.
I have saved the file and relaunched probe screen but it looks the same. What I'm I missing?
I am an android developer, and I have some experience with coding, perhaps I could help :)
btw, generally I'm a mac user and the linux pc is just in my shop with its purpose to run linuxcnc.
Can I edit the UI file in Qt Designer for mac and just push it to my github and pull it on the linux pc and test it?
Last edit: 7 years 4 weeks ago by vmihalca.
The following user(s) said Thank You: Lcvette
7 years 3 weeks ago #147475 by ssd
Replied by ssd on topic Another GUI project underway
Would it take a lot of effort to modify the GUI for a vertical screen? Something similar to that:
7 years 3 weeks ago #147476 by tommylight
There are two versions of a vertical screen for Linuxcnc, one that was never made public using the modified Axis GUI, and the other is still in development and looks similar to that path pilot you posted.
The second comes with Linuxcnc version 2.9, not sure if it is in 2.8.
The second is a version of the GUI developed in this thread, for vertical monitors.
The following user(s) said Thank You: Lcvette, ssd
7 years 3 weeks ago - 7 years 3 weeks ago #147477 by ssd
Thank you. I should have done some more research before making a reply. @Lcvette posted the previews on page 11.
BTW, you guys should set up a donation page. The GUI looks awesome and I am sure many of us would contribute.
Last edit: 7 years 3 weeks ago by ssd.
The following user(s) said Thank You: Lcvette, anfänger
7 years 3 weeks ago #147478 by Lcvette
ssd wrote: Would it take a lot of effort to modify the GUI for a vertical screen? Something similar to that:
yes but its not ready yet, we are finishing the primary screen first before i do anything else on the others so there is less work to be done other then formatting the layout.. the vertical screens are below as a rough example..
forum.linuxcnc.org/41-guis/34996-another...way?start=100#122765
The following user(s) said Thank You: ssd
Moderators: KCJ, Lcvette
Time to create page: 0.468 seconds
