Another GUI project underway
22 Dec 2019 08:02 #153016 by kayaba
Replied by kayaba on topic Another GUI project underway
Where get gui ,its so cool gui ever
The following user(s) said Thank You: Lcvette
22 Dec 2019 09:22 #153019 by 0x2102
22 Dec 2019 10:35 #153020 by kayaba
And what board suport it?its posible using lpt port?
Ihave plan using that,lpt port for stepping,then using arduino mega for inout output,
Thnk you
22 Dec 2019 10:48 - 22 Dec 2019 16:17 #153022 by 0x2102
Replied by 0x2102 on topic Another GUI project underway
This is a GUI for LinuxCNC. It can replace your existing GUI like Axis. If you LinuxCNC config works with Axis and should work with "Probe Basic" - I assume that is the qtpyvcp screen you are referring.
Requires LinuxCNC 2.8 or 2.9
Last edit: 22 Dec 2019 16:17 by 0x2102.
The following user(s) said Thank You: Lcvette, kayaba
  • Lcvette
  • Lcvette's Avatar Topic Author
  • Moderator
  • Moderator
22 Dec 2019 16:07 #153039 by Lcvette
Replied by Lcvette on topic Another GUI project underway
It requires debian stretch, buster or mint preempt rt kernels to work.
22 Dec 2019 16:44 #153045 by kayaba
Ok i ll try,thnk for help.
Im new in linux but was try in my friends machine retrofit,its so cool gcode running,excelent smooth running,
Machine just standart 3 axis,manual running with keyboard,i was using mach3 several years,but have problem,now and future will using linux,iam retrofitter,iam familiar with china control like ddscv,v1 /1.1,ecut board 1/1.2,eternet mach3 control,etc i was try but not so good,then for comercial machine i use szgh and adtech also gunt controller.
Next month i ll help new cust to retro hurco machine vm2 with linux,using lpt,and mpg pendant,
Idea 1,using 2 lpt port that suport stepconf and other for mpg,
Idea no2,using 1 lpt,free pin of lpt 1 handle encoder A B signal,then using hidcomp to selec axis and resolution..
So my queation is,what best gui for my aplication?
And for idea no 1 and 2 any thread for me??
Thank you ...
27 Dec 2019 07:51 #153255 by snoozer77
Replied by snoozer77 on topic Another GUI project underway
Hi Guys,
Just installed a new partition with mint 19.2 and 2.8 linuxcnc as per Tommy's instructions on his mint installation thread. All seems to work great, and runs my cnc router no probs.
Wanted to have a bit of a look at the probe basic sim, so ran through all the instructions on Kurt's qtpyvcp website. I also downloaded the bptouch and mill touch examples. i cant seem to see or access probe basic though. All the other examples are there, but no probe basic.
Not sure if i had done something wrong, or if it has been taken from the examples.
Any help would be great. Hope everyone is having a great festive season. Thanks Matt
27 Dec 2019 14:00 #153269 by Leon82
Replied by Leon82 on topic Another GUI project underway
You have to pick qtpyvcp sim first, then a second chooser comes up and should have all them in there
27 Dec 2019 14:17 #153271 by KCJ
Replied by KCJ on topic Another GUI project underway
Hello Matt,
ProbeBasic has been moved from the QtPyVCP examples to a separate repository to make it easier to maintain. The new PB documentation is located here: kcjengr.github.io/probe_basic
Happy Holidays!
Kurt
The following user(s) said Thank You: Lcvette, snoozer77, COFHAL
27 Dec 2019 14:42 #153277 by COFHAL
Replied by COFHAL on topic Another GUI project underway
This work with linuxcnc 2.9 ?
Moderators: KCJ, Lcvette
Time to create page: 0.275 seconds
