Another GUI project underway
- COFHAL
- Thank you received: 62
27 Dec 2019 15:44 #153290
by COFHAL
Replied by COFHAL on topic Another GUI project underway
I installed it but when executing it, an error appears regarding openGL, and I really don't know how to fix it.
ERROR: In /work/standalone-x64-build/VTK-source/Rendering/OpenGL2/vtkOpenGLRenderWindow.cxx, line 797
vtkXOpenGLRenderWindow (0x55a31eacb850): GL version 2.1 with the gpu_shader4 extension is not supported by your graphics driver but is required for the new OpenGL rendering backend. Please update your OpenGL driver. If you are using Mesa please make sure you have version 10.6.5 or later and make sure your driver in Mesa supports OpenGL 3.2.
The following user(s) said Thank You: Lcvette
- snoozer77
- Thank you received: 12
28 Dec 2019 20:56 #153376
by snoozer77
Replied by snoozer77 on topic Another GUI project underway
I had the same issue on my router machine running on an old PC. I don't think the graphics card / driver were adequate. (After googling OpenGL)
Installed on my gaming laptop with NVidia graphics card, all worked fine. (After having a battle with the laptop bios)
Sorry, not much of a help, but I noticed no-one has had the chance to reply.
If my explanation/reason is wrong, happy if someone corrects me. I'm a Linux noob...
The following user(s) said Thank You: Lcvette, COFHAL
- Thank you received: 7468
29 Dec 2019 01:27 #153385
Replied by tommylight on topic Another GUI project underway
Did you try software rendering ?
wiki.linuxcnc.org/cgi-bin/wiki.pl?Hardware_Requirements
- Hytek
- Thank you received: 8
18 Jan 2020 14:58 #155098
by Hytek
Replied by Hytek on topic Another GUI project underway
Hey Guys, this is my first post so please go easy on me. Or don't...
Firstly I would like to say what an AWESOME looking GUI!
I have a couple of questions, they may not be directly related to this GUI. Possibly more of a general Linuxcnc thing.
Is it possible to get the system to boot straight into the cnc screen? In other words hide the OS in the background on boot.
Do I need to have an ATC for this GUI?
Sorry if these questions seem a bit stupid. Prior to deciding to retrofit my mill I have only used the proprietary kit
Thanks in advance
Thanks in advance
18 Jan 2020 21:22 #155115
Search for "linux kiosk", that is the same thing for internet terminals.Is it possible to get the system to boot straight into the cnc screen? In other words hide the OS in the background on boot.
No, it should work without it.Do I need to have an ATC for this GUI?
- Hytek
19 Jan 2020 12:44 #155145
by Hytek
Thanks for the reply Tommylight. As I read the second answer it very quickly became one of those 'oh duhh' moments. Makes total sense when you say it like that
The following user(s) said Thank You: tommylight, Lcvette
- Nitram
- Thank you received: 15
02 Mar 2020 00:40 #158924
by Nitram
Replied by Nitram on topic Another GUI project underway
From the dev install on git:
2- Upgrade to LinuxCNC version 2.8
Is there a specific need for 2.8? Can Probe basic work with 2.7.xx as well?
Thanks.
Thanks.
- Lcvette
- Thank you received: 782
04 Mar 2020 02:09 - 04 Mar 2020 02:13 #159137
by Lcvette
no probe basic must run on 2.8 or 2.9, the reason is because probe basic was setup to use joints in the backend wiring and 2.7 does not use joints
Replied by Lcvette on topic Another GUI project underway
Thanks.
Last edit: 04 Mar 2020 02:13 by Lcvette.
- auto-mation-assist
- Thank you received: 81
13 Mar 2020 12:53 #160008
by auto-mation-assist
Replied by auto-mation-assist on topic Another GUI project underway
I have looked at all the posts relating to your project and I must say that your work is very impressive.
I hope to be able to get it installed in the next few days in v2.9, convert my configuration files as needed and can run some tests to get a good understanding of all your gui's features. It definitely makes me think that there is no need for me to proceed any further on gui development work that I have been doing on my own.
The following user(s) said Thank You: Lcvette, KCJ
- MovT
13 Mar 2020 15:00 #160021
by MovT
Replied by MovT on topic Another GUI project underway
Thanks for the impressive and nice work! I use Probe_Basic now and i like it. I am an experienced coder but not with python. Anyway i would be a helping hand.
Is there a description how to set up a development environment? I am sure i will be familiar in a short time.
My short goals are to bring the spindle load and speed widgets to get working. Also a translation into my native language "German" is a nice to have
Best,
Udo
Best,
Udo
Moderators: KCJ, Lcvette
Time to create page: 0.173 seconds
