Another GUI project underway
- Lcvette
- Thank you received: 782
13 Mar 2020 15:13 #160024
by Lcvette
yes the development installation is here:
kcjengr.github.io/probe_basic/dev_install.html
we welcome all help!
Replied by Lcvette on topic Another GUI project underway
Thanks for the impressive and nice work! I use Probe_Basic now and i like it. I am an experienced coder but not with python. Anyway i would be a helping hand.
Is there a description how to set up a development environment? I am sure i will be familiar in a short time.
My short goals are to bring the spindle load and speed widgets to get working. Also a translation into my native language "German" is a nice to have
Best,
Udo
- Lcvette
13 Mar 2020 15:14 #160025
by Lcvette
great, it runs fine so far on 2.9, i use that for dev and run 2.8 on test pc as well and have not run into any issues yet! feel free to stop by the qtpyvcp chat on irc!
Chris
I have looked at all the posts relating to your project and I must say that your work is very impressive.
I hope to be able to get it installed in the next few days in v2.9, convert my configuration files as needed and can run some tests to get a good understanding of all your gui's features. It definitely makes me think that there is no need for me to proceed any further on gui development work that I have been doing on my own.
Chris
- decor82
- Thank you received: 5
30 Mar 2020 13:40 #162110
by decor82
Replied by decor82 on topic Another GUI project underway
Hello,
I installed the probe basic screen and it is really great. The look and feel is outstanding!
I have one little problem. I live in Germany and work with metric system, but the DRO in the probe basic screen is in Inch. Can I change this to mm? I edited the ink file, but the result is the same.
Best regards,
Jan
Best regards,
Jan
The following user(s) said Thank You: Lcvette
- Lcvette
30 Mar 2020 13:59 - 30 Mar 2020 14:55 #162113
by Lcvette
sounds like you have not correctly changed all of your ini file settings maybe. i have metric working perfectly fine in the sim, try checking the atc_sim/vmc_index_metric.ini file as a template for the metric units display..
this line in particular:
LINEAR_UNITS = mm
also make sure the initialization string is changed from G20 to G21
Hello,
Best regards,
Jan
LINEAR_UNITS = mm
Last edit: 30 Mar 2020 14:55 by Lcvette.
- decor82
30 Mar 2020 15:23 #162125
by decor82
The G20 to G21 did the trick! thanks
- Bruedney
06 Apr 2020 08:40 #162871
by Bruedney
Replied by Bruedney on topic Another GUI project underway
Hi
A Linuxcnc nooby here
I really like this GUI but I can't find how to use it.
I have already had SilverDragon GUI working but would like to try this one.
Can someone please direct me in the right direction?
Cheers
Bruce
Cheers
Bruce
- MovT
06 Apr 2020 08:43 #162873
by MovT
Replied by MovT on topic Another GUI project underway
Try this Howto. Use LinuxCNC 2.8 or later to get the latest kinematic concept.
www.rainydayprojects.ch/linuxcnc/qtpyvcp-linuxcnc-gui
Best,
Udo
Best,
Udo
The following user(s) said Thank You: Bruedney
- Bruedney
06 Apr 2020 08:50 #162874
by Bruedney
Thanks - that was very helpful
- Lcvette
06 Apr 2020 17:41 #162942
by Lcvette
if you are just wanting to use the gui and not do dev work on it for yourself, then you can use this installation which is a users install, much cleaner and easier to update with stable releases.
kcjengr.github.io/probe_basic/quick_start.html
hope this helps!
Chris
Hi
Cheers
Bruce
hope this helps!
Chris
- Bruedney
07 Apr 2020 03:34 #163009
by Bruedney
OK so I have it all installed but I get this error
"ERROR: In /work/standalone-x64-build/VTK-source/Rendering/OpenGL2/vtkOpenGLRenderWindow.cxx, line 797
vtkXOpenGLRenderWindow (0x56378428fd80): GL version 2.1 with the gpu_shader4 extension is not supported by your graphics driver but is required for the new OpenGL rendering backend. Please update your OpenGL driver. If you are using Mesa please make sure you have version 10.6.5 or later and make sure your driver in Mesa supports OpenGL 3.2."
glxinfo | grep "OpenGL version" returns
"OpenGL version string: 2.1 Mesa 13.0.6"
Graphic card according to lspci is
"VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RV516 [Radeon X1300/X1550 Series]"
glxinfo | grep -i vendor returns
server glx vendor string: SGI
client glx vendor string: Mesa Project and SGI
Vendor: X.Org R300 Project (0x1002)
OpenGL vendor string: X.Org R300 Project
Any help would be appreciated
Bruce
Bruce
Moderators: KCJ, Lcvette
Time to create page: 0.842 seconds
