QtPyVCP Mill Touch V6
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
12 Jul 2019 00:01 #139130 by BigJohnT
Replied by BigJohnT on topic QtPyVCP Mill Touch V6
I'm assuming you did the following including the space dot at the end of pip3 install.
git clone https://github.com/jethornton/mill_touch_v6.git
cd mill_touch_v6
pip install -e .
in that case lets check if you have /home/username/.local/bin on the path by typing the following in a terminal.
echo $PATH
If that is not on the path then you need to add that by doing the following in a terminal.
printf 'if [ -d $HOME/.local/bin ]; then\n\texport PATH="$HOME/.local/bin:$PATH"\nfi' > .xsessionrc
Then either log out and back in or reboot.
JT
  • BigJohnT
  • Administrator
  • Administrator
12 Jul 2019 12:46 #139170 by BigJohnT
I'm testing my install on a fresh install of Debian 10 and I see I missed a dependency.
I'm creating some documentation for Mill Touch
jethornton.github.io/mill_touch_v6/index.html
JT
14 Jul 2019 09:51 #139294 by Ross77
Replied by Ross77 on topic QtPyVCP Mill Touch V6
I must be doing something wrong as i followed the instustions and it still wont load.
Im running Debian 9 and 2.7.14, do I need debian 10 and 2.8?
  • BigJohnT
  • Administrator
  • Administrator
14 Jul 2019 12:06 #139307 by BigJohnT
Yes, QtPyVCP requires at least 2.8.
JT
15 Jul 2019 22:53 #139511 by Ross77
Decided to start from scratch.
1. Debian9 live install from iso with 2.7.14
2 . Upgraded to 2.8 following your guide
3. installed QyPyVCP
4. Installed mill touch v6
I followed everything from jethornton.github.io/mill_touch_v6/install.html
It all seemed to install OK with no errors and I can open linuxcnc 2.8 with display as axis but as soon I change it to QtPyVCP I get an error log, see below. Any help would be aprreciated, Thanks
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0-pre1-4895-g85b013c55
Machine configuration directory is '/home/ross/linuxcnc/configs/my-mill_2.8'
Machine configuration file is 'my-mill_2.8.ini'
INIFILE=/home/ross/linuxcnc/configs/my-mill_2.8/my-mill_2.8.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=qtpyvcp VCP = mill_touch_v6
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./my-mill_2.8.hal
Found file(REL): ./custom.hal
Starting DISPLAY program: qtpyvcp
task: 68 cycles, min=0.000018, max=0.010113, avg=0.007920, 0 latency excursions (> 10x expected cycle time of 0.010000s)
config string '0 out'
Debug file information:
Note: Using POSIX realtime
Usage:
  qtpyvcp --ini=INI [<vcp>] [options]
  qtpyvcp (-h | --help)
  qtpyvcp (-v | --version)
9460
9488
Stopping realtime threads
Unloading hal components
Kernel message information:
[    0.000000] microcode: microcode updated early to revision 0xba, date = 2010-10-03
[    0.000000] Linux version 4.9.0-9-rt-amd64 (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) ) #1 SMP PREEMPT RT Debian 4.9.168-1+deb9u3 (2019-06-16)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-9-rt-amd64 root=UUID=cad3a776-569a-4a8a-959a-8bedc1c364e6 ro quiet
[    0.000000] x86/fpu: Legacy x87 FPU detected.
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
[    0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000bf4ff7ff] usable
[    0.000000] BIOS-e820: [mem 0x00000000bf4ff800-0x00000000bf553bff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000bf553c00-0x00000000bf555bff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000bf555c00-0x00000000bfffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fed003ff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed20000-0x00000000fed9ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000feefffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ffb00000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000001b7ffffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.5 present.
[    0.000000] DMI: Dell Inc. OptiPlex 755                 /0PU052, BIOS A10 04/30/2008
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0x1b8000 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-CFFFF write-protect
[    0.000000]   D0000-EFFFF uncachable
[    0.000000]   F0000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask 000000000 write-back
[    0.000000]   1 base 0BF700000 mask FFFF00000 uncachable
[    0.000000]   2 base 0BF800000 mask FFF800000 uncachable
[    0.000000]   3 base 0BF600000 mask FFFF00000 uncachable
[    0.000000]   4 base 0C0000000 mask FC0000000 uncachable
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- WT
[    0.000000] e820: update [mem 0xbf600000-0xffffffff] usable ==> reserved
[    0.000000] e820: last_pfn = 0xbf4ff max_arch_pfn = 0x400000000
[    0.000000] found SMP MP-table at [mem 0x000fe710-0x000fe71f] mapped at [ffff9b9ac00fe710]
[    0.000000] Base memory trampoline at [ffff9b9ac0099000] 99000 size 24576
[    0.000000] BRK [0x185a5000, 0x185a5fff] PGTABLE
[    0.000000] BRK [0x185a6000, 0x185a6fff] PGTABLE
[    0.000000] BRK [0x185a7000, 0x185a7fff] PGTABLE
[    0.000000] BRK [0x185a8000, 0x185a8fff] PGTABLE
[    0.000000] BRK [0x185a9000, 0x185a9fff] PGTABLE
[    0.000000] BRK [0x185aa000, 0x185aafff] PGTABLE
[    0.000000] BRK [0x185ab000, 0x185abfff] PGTABLE
[    0.000000] RAMDISK: [mem 0x351ef000-0x368eefff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000000FEC00 000024 (v02 DELL  )
[    0.000000] ACPI: XSDT 0x00000000000FC5B3 00008C (v01 DELL   B9K      00000015 ASL  00000061)
[    0.000000] ACPI: FACP 0x00000000000FC6E3 0000F4 (v03 DELL   B9K      00000015 ASL  00000061)
[    0.000000] ACPI BIOS Warning (bug): 32/64X length mismatch in FADT/Gpe0Block: 128/64 (20160831/tbfadt-603)
[    0.000000] ACPI: DSDT 0x00000000FFF76B39 004596 (v01 DELL   dt_ex    00001000 INTL 20050624)
[    0.000000] ACPI: FACS 0x00000000BF4FF800 000040
[    0.000000] ACPI: SSDT 0x00000000FFF7B1EE 0000AA (v01 DELL   st_ex    00001000 INTL 20050624)
[    0.000000] ACPI: APIC 0x00000000000FC7D7 000092 (v01 DELL   B9K      00000015 ASL  00000061)
[    0.000000] ACPI: BOOT 0x00000000000FC869 000028 (v01 DELL   B9K      00000015 ASL  00000061)
[    0.000000] ACPI: ASF! 0x00000000000FC891 000096 (v32 DELL   B9K      00000015 ASL  00000061)
[    0.000000] ACPI: MCFG 0x00000000000FC927 00003E (v01 DELL   B9K      00000015 ASL  00000061)
[    0.000000] ACPI: HPET 0x00000000000FC965 000038 (v01 DELL   B9K      00000015 ASL  00000061)
[    0.000000] ACPI: TCPA 0x00000000000FCBC1 000032 (v01 DELL   B9K      00000015 ASL  00000061)
[    0.000000] ACPI: ____ 0x00000000000FCBF3 000030 (v01 DELL   B9K      00000015 ASL  00000061)
[    0.000000] ACPI: SLIC 0x00000000000FC99D 000176 (v01 DELL   B9K      00000015 ASL  00000061)
[    0.000000] ACPI: SSDT 0x00000000BF4FF840 000175 (v01 DpgPmm Cpu0Ist  00000011 INTL 20050624)
[    0.000000] ACPI: SSDT 0x00000000BF4FFC49 000175 (v01 DpgPmm Cpu1Ist  00000011 INTL 20050624)
[    0.000000] ACPI: SSDT 0x00000000BF500052 000140 (v01 DpgPmm CpuPm    00000010 INTL 20050624)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x00000001b7ffffff]
[    0.000000] NODE_DATA(0) allocated [mem 0x1b7ff8000-0x1b7ffcfff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000001b7ffffff]
[    0.000000]   Device   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000009efff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x00000000bf4fefff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x00000001b7ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x00000001b7ffffff]
[    0.000000] On node 0 totalpages: 1537181
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 21 pages reserved
[    0.000000]   DMA zone: 3998 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 12180 pages used for memmap
[    0.000000]   DMA32 zone: 779519 pages, LIFO batch:31
[    0.000000]   Normal zone: 11776 pages used for memmap
[    0.000000]   Normal zone: 753664 pages, LIFO batch:31
[    0.000000] Reserving Intel graphics memory at 0x00000000bf800000-0x00000000bfffffff
[    0.000000] ACPI: PM-Timer IO Port: 0x808
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high level lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a301 base: 0xfed00000
[    0.000000] smpboot: Allowing 8 CPUs, 6 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x000effff]
[    0.000000] PM: Registered nosave memory: [mem 0x000f0000-0x000fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xbf4ff000-0xbf4fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xbf500000-0xbf552fff]
[    0.000000] PM: Registered nosave memory: [mem 0xbf553000-0xbf553fff]
[    0.000000] PM: Registered nosave memory: [mem 0xbf554000-0xbf554fff]
[    0.000000] PM: Registered nosave memory: [mem 0xbf555000-0xbf555fff]
[    0.000000] PM: Registered nosave memory: [mem 0xbf556000-0xbfffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xc0000000-0xdfffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xf0000000-0xfebfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfecfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed00000-0xfed1ffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed20000-0xfed9ffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfeda0000-0xfedfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfeefffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfef00000-0xffafffff]
[    0.000000] PM: Registered nosave memory: [mem 0xffb00000-0xffffffff]
[    0.000000] e820: [mem 0xc0000000-0xdfffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:8 nr_node_ids:1
[    0.000000] percpu: Embedded 116 pages/cpu @ffff9b9c71400000 s437952 r8192 d28992 u524288
[    0.000000] pcpu-alloc: s437952 r8192 d28992 u524288 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1 2 3 [0] 4 5 6 7
[    0.000000] Built 1 zonelists in Node order, mobility grouping on.  Total pages: 1513140
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-9-rt-amd64 root=UUID=cad3a776-569a-4a8a-959a-8bedc1c364e6 ro quiet
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Calgary: detecting Calgary via BIOS EBDA area
[    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.000000] Memory: 5943008K/6148724K available (6418K kernel code, 1154K rwdata, 2916K rodata, 1684K init, 856K bss, 205716K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] Kernel/User page tables isolation: enabled
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=8.
[    0.000000] 	RCU kthread priority: 1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.000000] NR_IRQS:33024 nr_irqs:488 16
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.000000] hpet clockevent registered
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 2327.508 MHz processor
[    0.004006] Calibrating delay loop (skipped), value calculated using timer frequency.. 4655.01 BogoMIPS (lpj=9310032)
[    0.004008] pid_max: default: 32768 minimum: 301
[    0.004022] ACPI: Core revision 20160831
[    0.071777] ACPI: 5 ACPI AML tables successfully acquired and loaded
[    0.071814] Security Framework initialized
[    0.071816] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.071823] AppArmor: AppArmor disabled by boot time parameter
[    0.073437] Dentry cache hash table entries: 1048576 (order: 12, 16777216 bytes)
[    0.084784] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.087608] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.087624] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.088267] mce: CPU supports 6 MCE banks
[    0.088275] CPU0: Thermal monitoring enabled (TM2)
[    0.088280] process: using mwait in idle threads
[    0.088285] Last level iTLB entries: 4KB 128, 2MB 4, 4MB 4
[    0.088286] Last level dTLB entries: 4KB 256, 2MB 0, 4MB 32, 1GB 0
[    0.088288] Spectre V2 : Mitigation: Full generic retpoline
[    0.088289] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.088290] Speculative Store Bypass: Vulnerable
[    0.088292] MDS: Vulnerable: Clear CPU buffers attempted, no microcode
[    0.088778] Freeing SMP alternatives memory: 24K
[    0.090137] ftrace: allocating 25266 entries in 99 pages
[    0.112163] smpboot: Max logical packages: 4
[    0.112548] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.156000] smpboot: CPU0: Intel(R) Core(TM)2 Duo CPU     E6550  @ 2.33GHz (family: 0x6, model: 0xf, stepping: 0xb)
[    0.156000] Performance Events: PEBS fmt0+, Core2 events, Intel PMU driver.
[    0.156000] core: PEBS disabled due to CPU errata
[    0.156000] ... version:                2
[    0.156000] ... bit width:              40
[    0.156000] ... generic registers:      2
[    0.156000] ... value mask:             000000ffffffffff
[    0.156000] ... max period:             000000007fffffff
[    0.156000] ... fixed-purpose events:   3
[    0.156000] ... event mask:             0000000700000003
[    0.208349] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.260025] x86: Booting SMP configuration:
[    0.260027] .... node  #0, CPUs:      #1
[    0.268100] x86: Booted up 1 node, 2 CPUs
[    0.268100] smpboot: Total of 2 processors activated (9310.03 BogoMIPS)
[    0.270149] devtmpfs: initialized
[    0.270149] x86/mm: Memory block size: 128MB
[    0.274747] PM: Registering ACPI NVS region [mem 0xbf4ff800-0xbf553bff] (345088 bytes)
[    0.274835] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.274879] futex hash table entries: 2048 (order: 6, 262144 bytes)
[    0.274993] pinctrl core: initialized pinctrl subsystem
[    0.275195] NET: Registered protocol family 16
[    0.280016] cpuidle: using governor ladder
[    0.284012] cpuidle: using governor menu
[    0.284032] Simple Boot Flag at 0x7a set to 0x1
[    0.284045] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.284047] ACPI: bus type PCI registered
[    0.284049] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.284152] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.284154] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.284162] pmd_set_huge: Cannot satisfy [mem 0xe0000000-0xe0200000] with a huge-page mapping due to MTRR override.
[    0.284280] PCI: Using configuration type 1 for base access
[    0.285316] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.285316] ACPI: Added _OSI(Module Device)
[    0.285316] ACPI: Added _OSI(Processor Device)
[    0.285316] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.285316] ACPI: Added _OSI(Processor Aggregator Device)
[    0.347248] ACPI: Interpreter enabled
[    0.348029] ACPI: (supports S0 S1 S3 S4 S5)
[    0.348030] ACPI: Using IOAPIC for interrupt routing
[    0.348149] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.359076] acpi LNXIOBAY:00: ACPI dock station (docks/bays count: 1)
[    0.520351] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.520357] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.520362] acpi PNP0A03:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[    0.530423] PCI host bridge to bus 0000:00
[    0.530426] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.530428] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.530430] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.530432] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000effff window]
[    0.530434] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff window]
[    0.530436] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfec00000 window]
[    0.530438] pci_bus 0000:00: root bus resource [mem 0xbf600000-0xdfffffff window]
[    0.530440] pci_bus 0000:00: root bus resource [mem 0xff980800-0xff980bff window]
[    0.530442] pci_bus 0000:00: root bus resource [mem 0xff97c000-0xff97ffff window]
[    0.530444] pci_bus 0000:00: root bus resource [mem 0xfed20000-0xfed9ffff window]
[    0.530446] pci_bus 0000:00: root bus resource [mem 0xfedad800-0xfedadfff window]
[    0.530449] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.530459] pci 0000:00:00.0: [8086:29b0] type 00 class 0x060000
[    0.530875] pci 0000:00:01.0: [8086:29b1] type 01 class 0x060400
[    0.530917] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.531264] pci 0000:00:01.0: System wakeup disabled by ACPI
[    0.531323] pci 0000:00:02.0: [8086:29b2] type 00 class 0x030000
[    0.531332] pci 0000:00:02.0: reg 0x10: [mem 0xfea00000-0xfea7ffff]
[    0.531338] pci 0000:00:02.0: reg 0x14: [io  0xec90-0xec97]
[    0.531343] pci 0000:00:02.0: reg 0x18: [mem 0xd0000000-0xdfffffff pref]
[    0.531349] pci 0000:00:02.0: reg 0x1c: [mem 0xfeb00000-0xfebfffff]
[    0.531757] pci 0000:00:02.1: [8086:29b3] type 00 class 0x038000
[    0.531766] pci 0000:00:02.1: reg 0x10: [mem 0xfea80000-0xfeafffff]
[    0.532192] pci 0000:00:03.0: [8086:29b4] type 00 class 0x078000
[    0.532204] pci 0000:00:03.0: reg 0x10: [mem 0xfedad000-0xfedad00f 64bit]
[    0.532245] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[    0.532632] pci 0000:00:03.2: [8086:29b6] type 00 class 0x010185
[    0.532642] pci 0000:00:03.2: reg 0x10: [io  0xfe80-0xfe87]
[    0.532648] pci 0000:00:03.2: reg 0x14: [io  0xfe90-0xfe93]
[    0.532653] pci 0000:00:03.2: reg 0x18: [io  0xfea0-0xfea7]
[    0.532659] pci 0000:00:03.2: reg 0x1c: [io  0xfeb0-0xfeb3]
[    0.532665] pci 0000:00:03.2: reg 0x20: [io  0xfef0-0xfeff]
[    0.533067] pci 0000:00:03.3: [8086:29b7] type 00 class 0x070002
[    0.533077] pci 0000:00:03.3: reg 0x10: [io  0xec98-0xec9f]
[    0.533083] pci 0000:00:03.3: reg 0x14: [mem 0xfe9da000-0xfe9dafff]
[    0.533523] pci 0000:00:19.0: [8086:10bd] type 00 class 0x020000
[    0.533538] pci 0000:00:19.0: reg 0x10: [mem 0xfe9e0000-0xfe9fffff]
[    0.533547] pci 0000:00:19.0: reg 0x14: [mem 0xfe9db000-0xfe9dbfff]
[    0.533555] pci 0000:00:19.0: reg 0x18: [io  0xecc0-0xecdf]
[    0.533613] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[    0.534001] pci 0000:00:1a.0: [8086:2937] type 00 class 0x0c0300
[    0.534041] pci 0000:00:1a.0: reg 0x20: [io  0xff20-0xff3f]
[    0.534413] pci 0000:00:1a.0: System wakeup disabled by ACPI
[    0.534474] pci 0000:00:1a.1: [8086:2938] type 00 class 0x0c0300
[    0.534514] pci 0000:00:1a.1: reg 0x20: [io  0xff00-0xff1f]
[    0.534887] pci 0000:00:1a.1: System wakeup disabled by ACPI
[    0.534955] pci 0000:00:1a.7: [8086:293c] type 00 class 0x0c0320
[    0.534973] pci 0000:00:1a.7: reg 0x10: [mem 0xfe9d9c00-0xfe9d9fff]
[    0.535055] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[    0.535449] pci 0000:00:1b.0: [8086:293e] type 00 class 0x040300
[    0.535465] pci 0000:00:1b.0: reg 0x10: [mem 0xfe9dc000-0xfe9dffff 64bit]
[    0.535534] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.535930] pci 0000:00:1c.0: [8086:2940] type 01 class 0x060400
[    0.535998] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.536353] pci 0000:00:1c.0: System wakeup disabled by ACPI
[    0.536424] pci 0000:00:1d.0: [8086:2934] type 00 class 0x0c0300
[    0.536464] pci 0000:00:1d.0: reg 0x20: [io  0xff80-0xff9f]
[    0.536837] pci 0000:00:1d.0: System wakeup disabled by ACPI
[    0.536895] pci 0000:00:1d.1: [8086:2935] type 00 class 0x0c0300
[    0.536935] pci 0000:00:1d.1: reg 0x20: [io  0xff60-0xff7f]
[    0.537309] pci 0000:00:1d.1: System wakeup disabled by ACPI
[    0.537367] pci 0000:00:1d.2: [8086:2936] type 00 class 0x0c0300
[    0.537406] pci 0000:00:1d.2: reg 0x20: [io  0xff40-0xff5f]
[    0.537780] pci 0000:00:1d.2: System wakeup disabled by ACPI
[    0.537846] pci 0000:00:1d.7: [8086:293a] type 00 class 0x0c0320
[    0.537864] pci 0000:00:1d.7: reg 0x10: [mem 0xff980800-0xff980bff]
[    0.537945] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[    0.538333] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[    0.538714] pci 0000:00:1e.0: System wakeup disabled by ACPI
[    0.538775] pci 0000:00:1f.0: [8086:2914] type 00 class 0x060100
[    0.538852] pci 0000:00:1f.0: quirk: [io  0x0800-0x087f] claimed by ICH6 ACPI/GPIO/TCO
[    0.538856] pci 0000:00:1f.0: quirk: [io  0x0880-0x08bf] claimed by ICH6 GPIO
[    0.538860] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0c00 (mask 007f)
[    0.538863] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 00e0 (mask 0007)
[    0.539275] pci 0000:00:1f.2: [8086:2920] type 00 class 0x01018f
[    0.539288] pci 0000:00:1f.2: reg 0x10: [io  0xfe00-0xfe07]
[    0.539296] pci 0000:00:1f.2: reg 0x14: [io  0xfe10-0xfe13]
[    0.539303] pci 0000:00:1f.2: reg 0x18: [io  0xfe20-0xfe27]
[    0.539311] pci 0000:00:1f.2: reg 0x1c: [io  0xfe30-0xfe33]
[    0.539319] pci 0000:00:1f.2: reg 0x20: [io  0xfec0-0xfecf]
[    0.539326] pci 0000:00:1f.2: reg 0x24: [io  0xeca0-0xecaf]
[    0.539739] pci 0000:00:1f.3: [8086:2930] type 00 class 0x0c0500
[    0.539754] pci 0000:00:1f.3: reg 0x10: [mem 0xfe9d9b00-0xfe9d9bff 64bit]
[    0.539774] pci 0000:00:1f.3: reg 0x20: [io  0xece0-0xecff]
[    0.540186] pci 0000:00:1f.5: [8086:2926] type 00 class 0x010185
[    0.540200] pci 0000:00:1f.5: reg 0x10: [io  0xfe40-0xfe47]
[    0.540208] pci 0000:00:1f.5: reg 0x14: [io  0xfe50-0xfe53]
[    0.540215] pci 0000:00:1f.5: reg 0x18: [io  0xfe60-0xfe67]
[    0.540223] pci 0000:00:1f.5: reg 0x1c: [io  0xfe70-0xfe73]
[    0.540230] pci 0000:00:1f.5: reg 0x20: [io  0xfed0-0xfedf]
[    0.540238] pci 0000:00:1f.5: reg 0x24: [io  0xecb0-0xecbf]
[    0.540686] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.540690] pci 0000:00:01.0:   bridge window [mem 0xfe800000-0xfe8fffff]
[    0.540746] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.540752] pci 0000:00:1c.0:   bridge window [mem 0xfe700000-0xfe7fffff]
[    0.540831] pci 0000:00:1e.0: PCI bridge to [bus 03] (subtractive decode)
[    0.540840] pci 0000:00:1e.0:   bridge window [io  0x0000-0x0cf7 window] (subtractive decode)
[    0.540842] pci 0000:00:1e.0:   bridge window [io  0x0d00-0xffff window] (subtractive decode)
[    0.540844] pci 0000:00:1e.0:   bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[    0.540847] pci 0000:00:1e.0:   bridge window [mem 0x000c0000-0x000effff window] (subtractive decode)
[    0.540849] pci 0000:00:1e.0:   bridge window [mem 0x000f0000-0x000fffff window] (subtractive decode)
[    0.540851] pci 0000:00:1e.0:   bridge window [mem 0xf0000000-0xfec00000 window] (subtractive decode)
[    0.540853] pci 0000:00:1e.0:   bridge window [mem 0xbf600000-0xdfffffff window] (subtractive decode)
[    0.540855] pci 0000:00:1e.0:   bridge window [mem 0xff980800-0xff980bff window] (subtractive decode)
[    0.540857] pci 0000:00:1e.0:   bridge window [mem 0xff97c000-0xff97ffff window] (subtractive decode)
[    0.540859] pci 0000:00:1e.0:   bridge window [mem 0xfed20000-0xfed9ffff window] (subtractive decode)
[    0.540861] pci 0000:00:1e.0:   bridge window [mem 0xfedad800-0xfedadfff window] (subtractive decode)
[    0.578235] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 15)
[    0.579138] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[    0.580067] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[    0.580983] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[    0.581901] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[    0.582807] ACPI: PCI Interrupt Link [LNKF] (IRQs *3 4 5 6 7 9 10 11 12 15)
[    0.583714] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[    0.584624] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[    0.585329] ACPI: Enabled 3 GPEs in block 00 to 3F
[    0.585444] vgaarb: setting as boot device: PCI:0000:00:02.0
[    0.585444] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[    0.585444] vgaarb: loaded
[    0.585444] vgaarb: bridge control possible 0000:00:02.0
[    0.585444] PCI: Using ACPI for IRQ routing
[    0.591048] PCI: pci_cache_line_size set to 64 bytes
[    0.591058] pci 0000:00:03.0: can't claim BAR 0 [mem 0xfedad000-0xfedad00f 64bit]: no compatible bridge window
[    0.591104] Expanded resource reserved due to conflict with PCI Bus 0000:00
[    0.591106] Expanded resource reserved due to conflict with PCI Bus 0000:00
[    0.591108] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
[    0.591110] e820: reserve RAM buffer [mem 0xbf4ff800-0xbfffffff]
[    0.591269] HPET: 4 timers in total, 0 timers will be used for per-cpu timer
[    0.591269] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
[    0.591269] hpet0: 4 comparators, 64-bit 14.318180 MHz counter
[    0.593027] clocksource: Switched to clocksource hpet
[    0.607331] VFS: Disk quotas dquot_6.6.0
[    0.607369] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.607513] pnp: PnP ACPI init
[    0.611509] pnp 00:00: disabling [io  0x0800-0x085f] because it overlaps 0000:00:1f.0 BAR 13 [io  0x0800-0x087f]
[    0.611512] pnp 00:00: disabling [io  0x0860-0x08ff] because it overlaps 0000:00:1f.0 BAR 13 [io  0x0800-0x087f]
[    0.611563] system 00:00: [io  0x0c00-0x0c7f] has been reserved
[    0.611569] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.611820] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.619859] pnp 00:02: [dma 2]
[    0.620378] pnp 00:02: Plug and Play ACPI device, IDs PNP0700 (active)
[    0.632779] pnp 00:03: [dma 0 disabled]
[    0.634002] pnp 00:03: Plug and Play ACPI device, IDs PNP0401 (active)
[    0.639441] pnp 00:04: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.653966] pnp: PnP ACPI: found 5 devices
[    0.661448] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.661469] pci 0000:00:1c.0: bridge window [io  0x1000-0x0fff] to [bus 02] add_size 1000
[    0.661472] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
[    0.661488] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.661490] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.661493] pci 0000:00:1c.0: res[13]=[io  0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[    0.661495] pci 0000:00:1c.0: res[13]=[io  0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[    0.661507] pci 0000:00:1c.0: BAR 15: assigned [mem 0xf0000000-0xf01fffff 64bit pref]
[    0.661511] pci 0000:00:1c.0: BAR 13: assigned [io  0x1000-0x1fff]
[    0.661518] pci 0000:00:03.0: BAR 0: assigned [mem 0xf0200000-0xf020000f 64bit]
[    0.661525] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.661529] pci 0000:00:01.0:   bridge window [mem 0xfe800000-0xfe8fffff]
[    0.661535] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.661538] pci 0000:00:1c.0:   bridge window [io  0x1000-0x1fff]
[    0.661542] pci 0000:00:1c.0:   bridge window [mem 0xfe700000-0xfe7fffff]
[    0.661546] pci 0000:00:1c.0:   bridge window [mem 0xf0000000-0xf01fffff 64bit pref]
[    0.661552] pci 0000:00:1e.0: PCI bridge to [bus 03]
[    0.661563] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.661565] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.661567] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.661569] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000effff window]
[    0.661571] pci_bus 0000:00: resource 8 [mem 0x000f0000-0x000fffff window]
[    0.661573] pci_bus 0000:00: resource 9 [mem 0xf0000000-0xfec00000 window]
[    0.661575] pci_bus 0000:00: resource 10 [mem 0xbf600000-0xdfffffff window]
[    0.661577] pci_bus 0000:00: resource 11 [mem 0xff980800-0xff980bff window]
[    0.661579] pci_bus 0000:00: resource 12 [mem 0xff97c000-0xff97ffff window]
[    0.661581] pci_bus 0000:00: resource 13 [mem 0xfed20000-0xfed9ffff window]
[    0.661583] pci_bus 0000:00: resource 14 [mem 0xfedad800-0xfedadfff window]
[    0.661585] pci_bus 0000:01: resource 1 [mem 0xfe800000-0xfe8fffff]
[    0.661588] pci_bus 0000:02: resource 0 [io  0x1000-0x1fff]
[    0.661590] pci_bus 0000:02: resource 1 [mem 0xfe700000-0xfe7fffff]
[    0.661592] pci_bus 0000:02: resource 2 [mem 0xf0000000-0xf01fffff 64bit pref]
[    0.661594] pci_bus 0000:03: resource 4 [io  0x0000-0x0cf7 window]
[    0.661596] pci_bus 0000:03: resource 5 [io  0x0d00-0xffff window]
[    0.661599] pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.661601] pci_bus 0000:03: resource 7 [mem 0x000c0000-0x000effff window]
[    0.661603] pci_bus 0000:03: resource 8 [mem 0x000f0000-0x000fffff window]
[    0.661605] pci_bus 0000:03: resource 9 [mem 0xf0000000-0xfec00000 window]
[    0.661607] pci_bus 0000:03: resource 10 [mem 0xbf600000-0xdfffffff window]
[    0.661609] pci_bus 0000:03: resource 11 [mem 0xff980800-0xff980bff window]
[    0.661611] pci_bus 0000:03: resource 12 [mem 0xff97c000-0xff97ffff window]
[    0.661613] pci_bus 0000:03: resource 13 [mem 0xfed20000-0xfed9ffff window]
[    0.661615] pci_bus 0000:03: resource 14 [mem 0xfedad800-0xfedadfff window]
[    0.661685] NET: Registered protocol family 2
[    0.661999] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[    0.662704] TCP bind hash table entries: 65536 (order: 9, 3670016 bytes)
[    0.664714] TCP: Hash tables configured (established 65536 bind 65536)
[    0.664877] UDP hash table entries: 4096 (order: 7, 524288 bytes)
[    0.665267] UDP-Lite hash table entries: 4096 (order: 7, 524288 bytes)
[    0.665712] NET: Registered protocol family 1
[    0.665744] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.671857] PCI: CLS 64 bytes, default 64
[    0.671945] Unpacking initramfs...
[    1.145568] Freeing initrd memory: 23552K
[    1.145575] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    1.145578] software IO TLB: mapped [mem 0xbb4ff000-0xbf4ff000] (64MB)
[    1.146308] audit: initializing netlink subsys (disabled)
[    1.146342] audit: type=2000 audit(1563207709.144:1): initialized
[    1.147098] workingset: timestamp_bits=40 max_order=21 bucket_order=0
[    1.150056] zbud: loaded
[    1.151361] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    1.151413] io scheduler noop registered
[    1.151415] io scheduler deadline registered
[    1.151467] io scheduler cfq registered (default)
[    1.152830] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    1.152838] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    1.152862] intel_idle: does not run on family 6 model 15
[    1.152990] GHES: HEST is not enabled!
[    1.153087] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.173519] 00:04: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    1.194423] 0000:00:03.3: ttyS1 at I/O 0xec98 (irq = 17, base_baud = 115200) is a 16550A
[    1.194838] Linux agpgart interface v0.103
[    1.195063] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    1.195064] AMD IOMMUv2 functionality not available on this system
[    1.195296] i8042: PNP: No PS/2 controller found. Probing ports directly.
[    1.198220] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.198275] serio: i8042 AUX port at 0x60,0x64 irq 12
[    1.198418] mousedev: PS/2 mouse device common for all mice
[    1.198472] rtc_cmos 00:01: RTC can wake from S4
[    1.198605] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[    1.198655] rtc_cmos 00:01: alarms up to one day, 242 bytes nvram, hpet irqs
[    1.199543] NET: Registered protocol family 10
[    1.199826] mip6: Mobile IPv6
[    1.199829] NET: Registered protocol family 17
[    1.199832] mpls_gso: MPLS GSO support
[    1.200050] microcode: sig=0x6fb, pf=0x1, revision=0xba
[    1.200105] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    1.200294] registered taskstats version 1
[    1.200322] zswap: loaded using pool lzo/zbud
[    1.200370] ima: No TPM chip found, activating TPM-bypass!
[    1.200372] ima: Allocated hash algorithm: sha256
[    1.200717] rtc_cmos 00:01: setting system clock to 2019-07-15 16:21:49 UTC (1563207709)
[    1.200775] PM: Hibernation image not present or could not be loaded.
[    1.202762] Freeing unused kernel memory: 1684K
[    1.202764] Write protecting the kernel read-only data: 12288k
[    1.203986] Freeing unused kernel memory: 1760K
[    1.207543] Freeing unused kernel memory: 1180K
[    1.214874] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.234707] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.234827] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.234843] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.284972] SCSI subsystem initialized
[    1.298872] pps_core: LinuxPPS API ver. 1 registered
[    1.298874] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.301201] ACPI: bus type USB registered
[    1.301235] usbcore: registered new interface driver usbfs
[    1.301256] usbcore: registered new interface driver hub
[    1.301446] PTP clock support registered
[    1.302974] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    1.302976] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.303546] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    1.303695] usbcore: registered new device driver usb
[    1.304737] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.305128] uhci_hcd: USB Universal Host Controller Interface driver
[    1.305798] ehci-pci: EHCI PCI platform driver
[    1.312625] libata version 3.00 loaded.
[    1.316811] Floppy drive(s): fd0 is 1.44M
[    1.342233] FDC 0 is a post-1991 82077
[    1.628316] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 00:1e:c9:74:b4:4c
[    1.628319] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[    1.628337] e1000e 0000:00:19.0 eth0: MAC: 7, PHY: 6, PBA No: 1041FF-0FF
[    1.628852] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[    1.628863] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[    1.628871] uhci_hcd 0000:00:1a.0: detected 2 ports
[    1.629113] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000ff20
[    1.629204] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[    1.629206] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.629208] usb usb1: Product: UHCI Host Controller
[    1.629211] usb usb1: Manufacturer: Linux 4.9.0-9-rt-amd64 uhci_hcd
[    1.629212] usb usb1: SerialNumber: 0000:00:1a.0
[    1.629412] hub 1-0:1.0: USB hub found
[    1.629423] hub 1-0:1.0: 2 ports detected
[    1.630158] ehci-pci 0000:00:1a.7: EHCI Host Controller
[    1.630165] ehci-pci 0000:00:1a.7: new USB bus registered, assigned bus number 2
[    1.630176] ehci-pci 0000:00:1a.7: debug port 1
[    1.634091] ehci-pci 0000:00:1a.7: cache line size of 64 is not supported
[    1.634310] ehci-pci 0000:00:1a.7: irq 22, io mem 0xfe9d9c00
[    1.648037] ehci-pci 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[    1.648156] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.648159] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.648161] usb usb2: Product: EHCI Host Controller
[    1.648163] usb usb2: Manufacturer: Linux 4.9.0-9-rt-amd64 ehci_hcd
[    1.648165] usb usb2: SerialNumber: 0000:00:1a.7
[    1.648337] hub 2-0:1.0: USB hub found
[    1.648349] hub 2-0:1.0: 6 ports detected
[    1.676114] hub 1-0:1.0: USB hub found
[    1.676126] hub 1-0:1.0: 2 ports detected
[    1.676816] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[    1.676980] ata_piix 0000:00:1f.2: version 2.13
[    1.677407] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[    1.840989] scsi host0: ata_piix
[    1.845194] scsi host1: ata_piix
[    1.845282] ata1: SATA max UDMA/133 cmd 0xfe00 ctl 0xfe10 bmdma 0xfec0 irq 18
[    1.845287] ata2: SATA max UDMA/133 cmd 0xfe20 ctl 0xfe30 bmdma 0xfec8 irq 18
[    1.850346] scsi host2: ata_generic
[    1.854532] scsi host3: ata_generic
[    1.854613] ata3: PATA max UDMA/100 cmd 0xfe80 ctl 0xfe90 bmdma 0xfef0 irq 18
[    1.854615] ata4: PATA max UDMA/100 cmd 0xfea0 ctl 0xfeb0 bmdma 0xfef8 irq 18
[    1.855092] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[    1.855100] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 3
[    1.855107] uhci_hcd 0000:00:1a.1: detected 2 ports
[    1.855170] uhci_hcd 0000:00:1a.1: irq 17, io base 0x0000ff00
[    1.855278] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    1.855281] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.855283] usb usb3: Product: UHCI Host Controller
[    1.855285] usb usb3: Manufacturer: Linux 4.9.0-9-rt-amd64 uhci_hcd
[    1.855287] usb usb3: SerialNumber: 0000:00:1a.1
[    1.855461] hub 3-0:1.0: USB hub found
[    1.855472] hub 3-0:1.0: 2 ports detected
[    1.856147] ehci-pci 0000:00:1d.7: EHCI Host Controller
[    1.856157] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 4
[    1.856171] ehci-pci 0000:00:1d.7: debug port 1
[    1.860069] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[    1.860117] ehci-pci 0000:00:1d.7: irq 23, io mem 0xff980800
[    2.176032] tsc: Refined TSC clocksource calibration: 2327.485 MHz
[    2.176037] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x218ca10e086, max_idle_ns: 440795242980 ns
[    2.380040] usb 1-1: new full-speed USB device number 2 using uhci_hcd
[    2.615052] usb 1-1: New USB device found, idVendor=04e7, idProduct=0020
[    2.615055] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.615057] usb 1-1: Product: Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface
[    2.615060] usb 1-1: Manufacturer: Elo TouchSystems, Inc.
[    2.615062] usb 1-1: SerialNumber: 20
[    2.628091] ata2.00: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    2.628103] ata2.01: SATA link down (SStatus 4 SControl 300)
[    2.628113] ata2.01: link offline, clearing class 3 to NONE
[    2.636089] ata1.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    2.636099] ata1.01: SATA link down (SStatus 4 SControl 300)
[    2.648143] ata2.00: ATAPI: PLDS DVD+/-RW DS-8W2S, 2D11, max UDMA/100
[    2.672139] ata2.00: configured for UDMA/100
[    2.685918] ata1.00: ATA-7: ST3160815AS, 4.ADA, max UDMA/133
[    2.685920] ata1.00: 312500000 sectors, multi 8: LBA48 NCQ (depth 0/32)
[    2.760879] ata1.00: configured for UDMA/133
[    2.761125] scsi 0:0:0:0: Direct-Access     ATA      ST3160815AS      A    PQ: 0 ANSI: 5
[    2.764040] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[    2.764142] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    2.764145] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.764147] usb usb4: Product: EHCI Host Controller
[    2.764150] usb usb4: Manufacturer: Linux 4.9.0-9-rt-amd64 ehci_hcd
[    2.764152] usb usb4: SerialNumber: 0000:00:1d.7
[    2.764338] hub 4-0:1.0: USB hub found
[    2.764348] hub 4-0:1.0: 6 ports detected
[    2.765070] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[    2.807201] scsi 1:0:0:0: CD-ROM            PLDS     DVD+-RW DS-8W2S  2D11 PQ: 0 ANSI: 5
[    2.928516] scsi host4: ata_piix
[    2.932713] scsi host5: ata_piix
[    2.932799] ata5: SATA max UDMA/133 cmd 0xfe40 ctl 0xfe50 bmdma 0xfed0 irq 18
[    2.932802] ata6: SATA max UDMA/133 cmd 0xfe60 ctl 0xfe70 bmdma 0xfed8 irq 18
[    2.933343] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[    2.933350] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 5
[    2.933357] uhci_hcd 0000:00:1d.0: detected 2 ports
[    2.933409] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000ff80
[    2.933514] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    2.933517] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.933519] usb usb5: Product: UHCI Host Controller
[    2.933521] usb usb5: Manufacturer: Linux 4.9.0-9-rt-amd64 uhci_hcd
[    2.933523] usb usb5: SerialNumber: 0000:00:1d.0
[    2.933694] hub 5-0:1.0: USB hub found
[    2.933705] hub 5-0:1.0: 2 ports detected
[    2.934335] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[    2.934341] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6
[    2.934348] uhci_hcd 0000:00:1d.1: detected 2 ports
[    2.934509] uhci_hcd 0000:00:1d.1: irq 17, io base 0x0000ff60
[    2.934605] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    2.934608] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.934610] usb usb6: Product: UHCI Host Controller
[    2.934612] usb usb6: Manufacturer: Linux 4.9.0-9-rt-amd64 uhci_hcd
[    2.934614] usb usb6: SerialNumber: 0000:00:1d.1
[    2.934781] hub 6-0:1.0: USB hub found
[    2.934792] hub 6-0:1.0: 2 ports detected
[    2.935371] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[    2.935377] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7
[    2.935383] uhci_hcd 0000:00:1d.2: detected 2 ports
[    2.935435] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ff40
[    2.935530] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    2.935533] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.935535] usb usb7: Product: UHCI Host Controller
[    2.935537] usb usb7: Manufacturer: Linux 4.9.0-9-rt-amd64 uhci_hcd
[    2.935539] usb usb7: SerialNumber: 0000:00:1d.2
[    2.935704] hub 7-0:1.0: USB hub found
[    2.935714] hub 7-0:1.0: 2 ports detected
[    3.148030] usb 1-2: new low-speed USB device number 3 using uhci_hcd
[    3.200090] clocksource: Switched to clocksource tsc
[    3.257161] ata5: SATA link down (SStatus 4 SControl 300)
[    3.257206] ata6: SATA link down (SStatus 4 SControl 300)
[    3.260035] usb 7-1: new low-speed USB device number 2 using uhci_hcd
[    3.260075] sd 0:0:0:0: [sda] 312500000 512-byte logical blocks: (160 GB/149 GiB)
[    3.260140] sd 0:0:0:0: [sda] Write Protect is off
[    3.260142] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    3.260168] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.280767] sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/6x writer cd/rw xa/form2 cdda pop-up
[    3.280769] cdrom: Uniform CD-ROM driver Revision: 3.20
[    3.280984] sr 1:0:0:0: Attached scsi CD-ROM sr0
[    3.311090]  sda: sda1 sda2 < sda5 >
[    3.311554] sd 0:0:0:0: [sda] Attached SCSI disk
[    3.318066] usb 1-2: New USB device found, idVendor=04f3, idProduct=0103
[    3.318069] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.324945] hidraw: raw HID events driver (C) Jiri Kosina
[    3.336045] random: fast init done
[    3.384338] usbcore: registered new interface driver usbhid
[    3.384340] usbhid: USB HID core driver
[    3.385597] input: Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1:1.0/0003:04E7:0020.0001/input/input3
[    3.385812] hid-generic 0003:04E7:0020.0001: input,hidraw0: USB HID v1.00 Pointer [Elo TouchSystems, Inc. Elo TouchSystems 2700 IntelliTouch(r) USB Touchmonitor Interface] on usb-0000:00:1a.0-1/input0
[    3.386238] input: HID 04f3:0103 as /devices/pci0000:00/0000:00:1a.0/usb1/1-2/1-2:1.0/0003:04F3:0103.0002/input/input4
[    3.386506] hid-generic 0003:04F3:0103.0002: input,hidraw1: USB HID v1.11 Keyboard [HID 04f3:0103] on usb-0000:00:1a.0-2/input0
[    3.397207] input: HID 04f3:0103 as /devices/pci0000:00/0000:00:1a.0/usb1/1-2/1-2:1.1/0003:04F3:0103.0003/input/input5
[    3.397275] hid-generic 0003:04F3:0103.0003: input,hidraw2: USB HID v1.11 Device [HID 04f3:0103] on usb-0000:00:1a.0-2/input1
[    3.445484] usb 7-1: New USB device found, idVendor=1a2c, idProduct=0042
[    3.445488] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.445491] usb 7-1: Product: Usb Mouse
[    3.445493] usb 7-1: Manufacturer: SEMICCHIP
[    3.462000] input: SEMICCHIP Usb Mouse as /devices/pci0000:00/0000:00:1d.2/usb7/7-1/7-1:1.0/0003:1A2C:0042.0004/input/input6
[    3.462116] hid-generic 0003:1A2C:0042.0004: input,hidraw3: USB HID v1.10 Mouse [SEMICCHIP Usb Mouse] on usb-0000:00:1d.2-1/input0
[    3.867007] PM: Starting manual resume from disk
[    3.867011] PM: Hibernation image partition 8:5 present
[    3.867012] PM: Looking for hibernation image.
[    3.867175] PM: Image not found (code -22)
[    3.867177] PM: Hibernation image not present or could not be loaded.
[    4.149396] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[    5.470743] ip_tables: (C) 2000-2006 Netfilter Core Team
[    5.570987] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    5.571180] systemd[1]: Detected architecture x86-64.
[    5.589619] systemd[1]: Set hostname to <cnc5>.
[    5.898129] random: crng init done
[    5.898132] random: 7 urandom warning(s) missed due to ratelimiting
[    6.862683] systemd[1]: live-tools.service: Cannot add dependency job, ignoring: Unit live-tools.service is masked.
[    6.863395] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    6.863712] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    6.863973] systemd[1]: Created slice User and Session Slice.
[    6.864051] systemd[1]: Listening on udev Kernel Socket.
[    6.864118] systemd[1]: Listening on Journal Socket (/dev/log).
[    6.864223] systemd[1]: Listening on Journal Audit Socket.
[    7.485543] lp: driver loaded but no devices found
[    7.561197] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[    7.787116] ppdev: user-space parallel port driver
[    7.797328] parport_pc 00:03: reported by Plug and Play ACPI
[    7.797406] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP]
[    7.892118] lp0: using parport0 (interrupt-driven).
[    8.135489] systemd-journald[229]: Received request to flush runtime journal from PID 1
[    9.868380] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input7
[    9.868387] ACPI: Power Button [VBTN]
[    9.868485] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input8
[    9.868488] ACPI: Power Button [PWRF]
[   10.040964] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[   10.332506] input: PC Speaker as /devices/platform/pcspkr/input/input9
[   10.423100] [drm] Initialized
[   10.474313] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x0000000000000828-0x000000000000082D (\GLBC) (20160831/utaddress-247)
[   10.474321] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x000000000000082A-0x000000000000082A (\SACT) (20160831/utaddress-247)
[   10.474326] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x0000000000000828-0x0000000000000828 (\SSTS) (20160831/utaddress-247)
[   10.474331] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[   10.474334] ACPI Warning: SystemIO range 0x00000000000008B0-0x00000000000008BF conflicts with OpRegion 0x00000000000008B8-0x00000000000008BB (\GIC2) (20160831/utaddress-247)
[   10.474338] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[   10.474340] ACPI Warning: SystemIO range 0x0000000000000880-0x00000000000008AF conflicts with OpRegion 0x000000000000088C-0x000000000000088F (\GIC1) (20160831/utaddress-247)
[   10.474344] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[   10.474345] lpc_ich: Resource conflict(s) found affecting gpio_ich
[   10.599230] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   10.599290] sr 1:0:0:0: Attached scsi generic sg1 type 5
[   10.628923] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[   11.157382] pci 0000:00:00.0: Intel Q35 Chipset
[   11.157398] pci 0000:00:00.0: detected gtt size: 524288K total, 262144K mappable
[   11.159647] pci 0000:00:00.0: detected 8192K stolen memory
[   11.159681] [drm] Memory usable by graphics device = 512M
[   11.159684] [drm] Replacing VGA console driver
[   11.160347] Console: switching to colour dummy device 80x25
[   11.207314] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   11.207316] [drm] Driver supports precise vblank timestamp query.
[   11.220406] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[   11.222445] [drm] RC6 disabled, disabling runtime PM support
[   11.222453] [drm] initialized overlay support
[   11.223292] [drm] Initialized i915 1.6.0 20160919 for 0000:00:02.0 on minor 0
[   11.281534] fbcon: inteldrmfb (fb0) is primary device
[   11.341503] Console: switching to colour frame buffer device 160x64
[   11.411366] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[   11.454249] iTCO_vendor_support: vendor-support=0
[   11.758637] snd_hda_codec_analog hdaudioC0D0: autoconfig for AD1984: line_outs=1 (0x12/0x0/0x0/0x0/0x0) type:line
[   11.758640] snd_hda_codec_analog hdaudioC0D0:    speaker_outs=1 (0x13/0x0/0x0/0x0/0x0)
[   11.758643] snd_hda_codec_analog hdaudioC0D0:    hp_outs=1 (0x11/0x0/0x0/0x0/0x0)
[   11.758645] snd_hda_codec_analog hdaudioC0D0:    mono: mono_out=0x0
[   11.758647] snd_hda_codec_analog hdaudioC0D0:    inputs:
[   11.758649] snd_hda_codec_analog hdaudioC0D0:      Mic=0x14
[   11.758651] snd_hda_codec_analog hdaudioC0D0:      Line=0x15
[   11.771356] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[   11.772189] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[   11.772347] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[   11.772439] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[   11.772535] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[   11.929250] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[   11.929305] iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
[   12.437735] usbcore: registered new interface driver usbtouchscreen
[   12.551423] kvm: disabled by bios
[   12.581719] kvm: disabled by bios
[   12.769438] coretemp coretemp.0: Using relative temperature scale!
[   12.769455] coretemp coretemp.0: Using relative temperature scale!
[   13.083300] intel_powerclamp: No package C-state available
[   13.603189] Adding 6147068k swap on /dev/sda5.  Priority:-1 extents:1 across:6147068k FS
[   18.232284] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   20.424863] e1000e: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
[   20.425013] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[  501.245203] systemd[1]: anacron.timer: Adding 4min 25.756ms random time.
[  501.245408] systemd[1]: apt-daily.timer: Adding 4h 10min 5.713036s random time.
[  501.246518] systemd[1]: apt-daily-upgrade.timer: Adding 32min 58.783753s random time.
[20296.567724] perf: interrupt took too long (2520 > 2500), lowering kernel.perf_event_max_sample_rate to 79250
[20574.955715] perf: interrupt took too long (3154 > 3150), lowering kernel.perf_event_max_sample_rate to 63250
[21030.824186] qtpyvcp[8263]: segfault at 0 ip           (null) sp 00007fff77432578 error 14 in python2.7[55effe4f6000+322000]
[21357.138267] perf: interrupt took too long (3954 > 3942), lowering kernel.perf_event_max_sample_rate to 50500
Info report created by linuxcnc_info:
The file:    /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
     http://pastebin.com
in order to provide information about the linuxcnc
system and configuration.
                Date: Mon 15 Jul 23:40:19 BST 2019
            UTC Date: Mon 15 Jul 22:40:19 UTC 2019
        this program: /usr/bin/linuxcnc_info
              uptime: 23:40:19 up 6:18, 1 user, load average: 0.44, 0.37, 0.31
     lsb_release -sa: Debian Debian GNU/Linux 9.9 (stretch) 9.9 stretch
      which linuxcnc: /usr/bin/linuxcnc
                 pwd: /home/ross/linuxcnc/configs/my-mill_2.8
                USER: ross
             LOGNAME: ross
                HOME: /home/ross
              EDITOR:
              VISUAL:
            LANGUAGE: en_GB:en
                TERM: dumb
           COLORTERM:
             DISPLAY: :0.0
             DESKTOP: lightdm-xsession
        display size: 1280x1024 pixels (338x270 millimeters)
                PATH: /usr/bin:/home/ross/linuxcnc/configs/my-mill_2.8/bin:/usr/bin:/home/ross/.local/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
         nodename -n: cnc5
      kernel-name -s: Linux
      kernel-vers -v: #1 SMP PREEMPT RT Debian 4.9.168-1+deb9u3 (2019-06-16)
          machine -m: x86_64
        processor -p: unknown
         platform -i: unknown
      oper system -o: GNU/Linux
/proc items:
             cmdline: BOOT_IMAGE=/boot/vmlinuz-4.9.0-9-rt-amd64 root=UUID=cad3a776-569a-4a8a-959a-8bedc1c364e6 ro quiet
          model name: Intel(R) Core(TM)2 Duo CPU E6550 @ 2.33GHz
               cores: 2
             cpu MHz: 2333.000
             parport: 0000-0000 : parport0 0000-0000 : parport0
              serial: 0000-0000 : serial 0000-0000 : serial
Versions:
                 gcc: gcc (Debian 6.3.0-18+deb9u1) 6.3.0 20170516
              python: Python 2.7.13
                 git: git version 2.11.0
          git commit: NA
                 tcl: 8.6
                  tk: 8.6
               glade: not_in_PATH
          glade-gtk2: not_in_PATH
linuxcnc_var all:
     LINUXCNCVERSION: 2.8.0-pre1-4895-g85b013c55
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
            REALTIME: /etc/init.d/realtime
                 RTS: uspace
          HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                Version                      Architecture Description
un  linuxcnc            <none>                       <none>       (no description available)
un  linuxcnc-dev        <none>                       <none>       (no description available)
un  linuxcnc-doc        <none>                       <none>       (no description available)
ii  linuxcnc-doc-en     1:2.7.14                     all          motion controller for CNC machines and robots (English documentation)
un  linuxcnc-sim        <none>                       <none>       (no description available)
un  linuxcnc-sim-dev    <none>                       <none>       (no description available)
ii  linuxcnc-uspace     1:2.8.0~pre1.4895.g85b013c55 amd64        motion controller for CNC machines and robots
ii  linuxcnc-uspace-dev 1:2.8.0~pre1.4895.g85b013c55 amd64        PC based motion controller for real-time Linux
15 Jul 2019 23:57 #139516 by PCW
Replied by PCW on topic QtPyVCP Mill Touch V6
Usage:
Suggests that qtpyvcp was not launched correctly (with the ini file name?)
Also for Preempt-RT the kernel log will not typically have any LinuxCNC related error messages
These error messages are printed on the console when you start LinuxCNC so its usually better to launch
LinuxCNC from the terminal when debugging
  • BigJohnT
  • Administrator
  • Administrator
15 Jul 2019 23:59 #139517 by BigJohnT
What config are you trying to run?
The error "config string '0 out'" looks like a parallel port config string.
Did you copy my simulator config and run that?
JT
16 Jul 2019 00:13 #139522 by KCJ
Replied by KCJ on topic QtPyVCP Mill Touch V6
From the error message you're getting it looks like there might be a formatting error in the INI file. Make sure that it looks like this, with the DISPLAY and VCP options on separate lines.
[DISPLAY]
DISPLAY = qtpyvcp
VCP = mill_touch_v6
KCJ
The following user(s) said Thank You: Ross77
16 Jul 2019 07:35 #139543 by Ross77
Opps, Copied the Display line verbatim so it was all one line.
DISPLAY = qtpyvcp VCP = mill_touch_v6
So that seems to have solved that issue but looks like there a few more yet. I opened axis sim and then changed display to QtPyVCP got the error below. It looks like it is a graphics issue, is that correct? I can also run the QtPyVCP sim and the basic Brender but everything else crashes
ERROR: In /work/standalone-x64-build/VTK-source/Rendering/OpenGL2/vtkOpenGLRenderWindow.cxx, line 797
vtkXOpenGLRenderWindow (0x55cc3c5cb3b0): GL version 2.1 with the gpu_shader4 extension is not supported by your graphics driver but is required for the new OpenGL rendering backend. Please update your OpenGL driver. If you are using Mesa please make sure you have version 10.6.5 or later and make sure your driver in Mesa supports OpenGL 3.2.
/usr/bin/linuxcnc: line 896:  1950 Segmentation fault      $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
1900
1945
  • Moderator
  • Moderator
16 Jul 2019 08:32 #139546 by tommylight
Replied by tommylight on topic QtPyVCP Mill Touch V6
It needs OpenGL 3.2 but 2.1 is installed.
If i am not mistaken you have to upgrade mesa-utils or similar. Or just do a
Sudo apt update
Sudo apt dist-upgrade
Moderators: KCJLcvette
Time to create page: 1.909 seconds
