QtPyVCP Mill Touch V6
7 years 3 months ago #139543 by Ross77
Replied by Ross77 on topic QtPyVCP Mill Touch V6
Opps, Copied the Display line verbatim so it was all one line.
DISPLAY = qtpyvcp VCP = mill_touch_v6
So that seems to have solved that issue but looks like there a few more yet. I opened axis sim and then changed display to QtPyVCP got the error below. It looks like it is a graphics issue, is that correct? I can also run the QtPyVCP sim and the basic Brender but everything else crashes
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl: ERROR: In /work/standalone-x64-build/VTK-source/Rendering/OpenGL2/vtkOpenGLRenderWindow.cxx, line 797 vtkXOpenGLRenderWindow (0x55cc3c5cb3b0): GL version 2.1 with the gpu_shader4 extension is not supported by your graphics driver but is required for the new OpenGL rendering backend. Please update your OpenGL driver. If you are using Mesa please make sure you have version 10.6.5 or later and make sure your driver in Mesa supports OpenGL 3.2. /usr/bin/linuxcnc: line 896: 1950 Segmentation fault $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS 1900 1945 Stopping realtime threads Unloading hal components Note: Using POSIX realtime
7 years 3 months ago #139546 by tommylight
Replied by tommylight on topic QtPyVCP Mill Touch V6
It needs OpenGL 3.2 but 2.1 is installed.
If i am not mistaken you have to upgrade mesa-utils or similar. Or just do a
Sudo apt update
Sudo apt dist-upgrade
7 years 3 months ago #139559 by PCW
Replied by PCW on topic QtPyVCP Mill Touch V6
Theres also the possibility that OpenGL 3.2 is not supported by your Graphic hardware
(too old) I ran into this on a HP DC7800, about the same vintage as your Dell Optiplex 755...
The fix is a newer computer or adding a video card.
The following user(s) said Thank You: BigJohnT
7 years 3 months ago #139628 by Ross77
Thanks for all the replies and help. I'll have to order a Graphics card or look at a new PC. The Dell optilex was probably ok for running mesa cards on axis but if want to use the newer GUI's then a new pc is on the cards.
Sorry to clog up this thread, I'll post a new one once I have got the new card or PC. Thanks again.
7 years 3 months ago #139657 by andypugh
7 years 4 weeks ago - 7 years 4 weeks ago #147038 by LinuksGuru
Replied by LinuksGuru on topic QtPyVCP Mill Touch V6
Hi!
Many thanks for the excellent piece of software!
I had run
cd ~ git clone https://github.com/jethornton/mill_touch_v6.git cd mill_touch_v6 pip install -e . cp -rv ~/mill_touch_v6/mill_touch_v6 ~/linuxcnc/configs/ cat ~/mill_touch_v6/scripts/.xsessionrc >> ~/.xsessionrc
Where should I create my ini file? Inside "~/linuxcnc/configs/mill_touch_v6" ?
Is it enough to change in Axis mill ini sample file (which could be taken as a template) "DISPLAY = qtpyvcp VCP = mill_touch_v6", in order to run mill touch v6 as demo?
Last edit: 7 years 4 weeks ago by LinuksGuru.
Moderators: KCJ, Lcvette
Time to create page: 0.296 seconds
