- User Interfaces
- Other User Interfaces
- QtPyVCP
- QtPyVCP - GCodeEditor - Widget Styling - Please review and comment.
- Leon82
- Thank you received: 79
27 Dec 2019 07:20 #153264
by Leon82
Replied by Leon82 on topic QtPyVCP - GCodeEditor - Widget Styling - Please review and comment.
Do we drop your gcode editor.py and replace the one in the qtpyvcp folder?
- Donb9261
- Thank you received: 103
27 Dec 2019 07:24 #153265
by Donb9261
Replied by Donb9261 on topic QtPyVCP - GCodeEditor - Widget Styling - Please review and comment.
Not sure I understand the question.
- Donb9261
27 Dec 2019 07:28 #153266
by Donb9261
The gcodeeditor.py I posted works so in theory one could simply exchange the original as shipped gcodeeditor.py file for mine. I just renamed the original as shipped to gcodeeditor.py.old and then placed mine in the folder without the .old extension allowing for the correct module import using my version.
The following user(s) said Thank You: Leon82
- Leon82
27 Dec 2019 07:58 #153268
by Leon82
Yes, i navigated to the folder which contained that file renamed original and dropped in yours. I'll try it again
- Donb9261
27 Dec 2019 08:15 #153270
by Donb9261
It could be that it searches based on the head portion of the file. So, try renaming the old one to gcodeeditor_old.py. This would forego any head lookup tagging that file first.
- Donb9261
27 Dec 2019 08:18 #153272
by Donb9261
And just to clarify the file path:
/home/YOUR_USER_NAME/.local/lib/python2.7/site-packages/qtpyvcp/widgets/input_widgets/gcodeeditor.py
- Donb9261
27 Dec 2019 08:23 #153273
by Donb9261
Ooops.... Typo.... missing underscore
/home/YOUR_USER_NAME/.local/lib/python2.7/site-packages/qtpyvcp/widgets/input_widgets/gcode_editor.py
- KCJ
- Thank you received: 267
27 Dec 2019 08:34 #153274
by KCJ
Replied by KCJ on topic QtPyVCP - GCodeEditor - Widget Styling - Please review and comment.
Assuming you have installed from a git checkout you could also modify/replace the file in qtpyvcp/widgets/input_widgets/gcode_editor.py and reinstall with ‘pip install -editable .’ (uninstall with pip uninstall qtpyvcp first if you don’t already have an editable install). From then on you can edit files without having to reinstall or copy the modified files to the python lib. Very handy for development!
The following user(s) said Thank You: Donb9261
- Leon82
27 Dec 2019 08:40 #153275
by Leon82
thats the one i replaced last night. ill double check the other path
- Donb9261
27 Dec 2019 08:40 #153276
by Donb9261
Wait until you see my next project. Macro var editor. Will load the .var file and display the contents for the work offsets allowing for a dialog less editing of all work offsets. Working through the bugs now.
Will use a QTableWidget like the tool table. I will also have an extension that will show user defined vars 500-5000. Handy when you use Probing macros and need to edit stored values without cluttering the UI.
Will work very similar to Fanuc Macro Variable Type B.
Maybe a week out.
Maybe a week out.
Moderators: KCJ, Lcvette
- User Interfaces
- QtPyVCP
Time to create page: 0.613 seconds
