just updated with:
pip install --upgrade vtk
...added to INI:
[ATC]
POCKETS=12
.... and still error apeared:
File "/home/cnc/.local/bin/probe_basic", line 11, in <module>
load_entry_point('probe-basic', 'gui_scripts', 'probe_basic')()
File "/home/cnc/qtpyvcp/pyqt5designer/Qt5.7.1-64bit/probe_basic/probe_basic/__init__.py", line 20, in main
qtpyvcp.run_vcp(opts, VCP_CONFIG_FILE)
File "/home/cnc/.local/lib/python2.7/site-packages/qtpyvcp/__init__.py", line 142, in run_vcp
launch_application(opts, config)
File "/home/cnc/.local/lib/python2.7/site-packages/qtpyvcp/vcp_launcher.py", line 78, in launch_application
loadWindows(config)
File "/home/cnc/.local/lib/python2.7/site-packages/qtpyvcp/vcp_launcher.py", line 211, in loadWindows
window = _initialize_object_from_dict(window_dict)
File "/home/cnc/.local/lib/python2.7/site-packages/qtpyvcp/vcp_launcher.py", line 205, in _initialize_object_from_dict
return obj(*args, **kwargs)
File "/home/cnc/qtpyvcp/pyqt5designer/Qt5.7.1-64bit/probe_basic/probe_basic/probe_basic.py", line 23, in __init__
super(ProbeBasic, self).__init__(*args, **kwargs)
File "/home/cnc/.local/lib/python2.7/site-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 43, in __init__
self.loadUi(ui_file)
File "/home/cnc/.local/lib/python2.7/site-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 102, in loadUi
uic.loadUi(ui_file, self)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/__init__.py", line 226, in loadUi
return DynamicUILoader(package).loadUi(uifile, baseinstance, resource_suffix)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/Loader/loader.py", line 72, in loadUi
return self.parse(filename, resource_suffix, basedir)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 1021, in parse
actor(elem)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 828, in createUserInterface
self.traverseWidgetTree(elem)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 806, in traverseWidgetTree
handler(self, child)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 273, in createWidget
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 503, in createLayout
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 546, in handleItem
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 264, in createWidget
self.stack.push(self.setupObject(widget_class, parent, elem))
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 228, in setupObject
obj = self.factory.createQObject(clsname, name, args, is_attribute)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/objcreator.py", line 100, in createQObject
factory = self.findQObjectType(classname)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/objcreator.py", line 125, in findQObjectType
w = module.search(classname)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/Loader/qobjectcreator.py", line 113, in search
module = __import__(mname, {}, {}, (cls,))
ImportError: No module named dro_label
Thank you
