How to add picture graphic image to gui qtpyvcp
5 years 8 months ago #197519 by Lcvette
you need to place the label where you want it, then select it and in the property editor under QLabel/test/pixmap there is a drop down manu, select "choose resource" then in the new window that opens click on images, then select your image and click OK should be there, then you shouod run . qcompile and check your ui it should be there!
5 years 8 months ago #197533 by aleksamc
I think you will not believe me, but I did everything as you said. And I see image in qtdevelopper, and compilling finished witout errors. But linuxcnc still opens with blank image.
5 years 8 months ago #197553 by Lcvette
I just tested and it is working, im not sure why yours is not? what version of qtpyvcp do you have installed?
5 years 8 months ago #197706 by aleksamc
In Qt Designer is evrything fine, I see picture well.
But in Linuxcnc it's blank.
So linuxcnc is 2.8.1 version
and QtDesigner version is 5.11.3 as same as Qt.
All plugins are run except libpyqt5_py3.so
Could you add here some of yours picture that I could try to add and to see if problem is not in file?
5 years 8 months ago #197804 by Lcvette
All the images used are available in the github probe basic image file!
4 years 7 months ago #239040 by joel
I need C axis Jog buttons. What graphics program was used to make the others? I messed around with GIMP for an hour and not getting anywhere. Thanks much.
Moderators: KCJ, Lcvette
Time to create page: 0.053 seconds
