Ref Z references X axis
5 years 8 months ago #197516 by Lcvette
Replied by Lcvette on topic Ref Z references X axis
ref all button is just a command of all axis to home, you have a signal crossed up somewhere. you should really compare the simulation ini file to your mchine ini file and make sure that the items needed for probe basic are in tyour machine configuration file, if it is missing some of them you could be missing some of the functionality probe basic has. as for gmoccapy, i am not sure, but if you run the simulation of probe basic, is it correct or wrong? if it is correct then you know the interface is commanding the correct axis to move because those configurations are known good! that is where i would start.
5 years 8 months ago #197517 by mf290997
Replied by mf290997 on topic Ref Z references X axis
Sorry if thats a dumb question, but I've never heard of this simulation(file). A quick google search didn't give me any real information apart from an ATC simulation. Do you have a link with infos about this.
5 years 8 months ago #197518 by Lcvette
under linuxcnc where you go to run your config there are other configs that are simulation configs that you can run probe basic without being connected to a machine
they use real configs but simulate movement so you can learn the interface and play around in it.
5 years 8 months ago #199211 by Lcvette
mf290997 wrote: Sorry if thats a dumb question, but I've never heard of this simulation(file). A quick google search didn't give me any real information apart from an ATC simulation. Do you have a link with infos about this.
did you get everything resolved?
5 years 7 months ago #201149 by mf290997
No, suddenly the Ref Z button does nothing anymore. In the beginning it homed the X Axis. I didn't change anything in the meantime. I realized that I would never really need this button as I always just home all the axis together. Therefore I didn't bother digging deeper into this issue.
Moderators: KCJ, Lcvette
Time to create page: 0.318 seconds
