Ref Z references X axis
5 years 8 months ago #197510 by mf290997
Replied by mf290997 on topic Ref Z references X axis
The issue is only present when pressing the REF Z button. Where can I find these configs shown in the screenshot? or can yo check if the REF Z button says machine.home.axis:z?
5 years 8 months ago #197511 by Lcvette
Replied by Lcvette on topic Ref Z references X axis
perhaps your ini and hal files are mixed up?
5 years 8 months ago #197512 by Lcvette
5 years 8 months ago #197513 by mf290997
Thanks. I'll post my files tomorrow.
5 years 8 months ago #197514 by Lcvette
mf290997 wrote: The issue is only present when pressing the REF Z button. Where can I find these configs shown in the screenshot? or can yo check if the REF Z button says machine.home.axis:z?
those are NOT configs they are the interface and it is correct, your configs are incorrect and need to be fixed, changing the interface will cause some pretty big issues for you and changing those around isn't the solution. go through your ini and hal file and im sure you will find the issue!
5 years 8 months ago #197515 by mf290997
I will definitely do that. But what I don't really understand: how is it possible that my ini or hal is wrong, if the same files work correctly in gmoccapy and also in probe_basic when clicking the reference all button.
When i installed probe_basic, I also had some errors when doing
sudo apt upgrade
and
sudo apt install python-pyqt5 python-pyqt5.qtquick python-dbus.mainloop.pyqt5 python-pyqt5.qtopengl python-pyqt5.qsci python-pyqt5.qtmultimedia qml-module-qtquick-controls gstreamer1.0-plugins-bad libqt5multimedia5-plugins pyqt5-dev-tools python-dev python-wheel python-setuptools python-pip git python-pyqtgraph python-pyqt5.qtwebkit
. I asked a friend of mine for quick help and I think he just deleted the parts from my system that had problems and afterwards it installed everything without errors. I guess that could be a problem, too, even though I don't know how this could only affect one button that does almost the same as the other buttons for X and Y.
Maybe I should try a fresh Linuxcnc and probe basic install. Can you confirm that the instructions shown here are all that should be needed to install probe_basic without errors?
Moderators: KCJ, Lcvette
