Probe Basic, error after reinstallation
18 Aug 2021 11:46 - 18 Aug 2021 11:54 #218079 by Roger S
Hi, everyone,i have reinstalled linuxcnc and the probe basic screen:LinuxCNC 2.8.2 Debian 10 Buster PREEMPT-RT ISO
github.com/kcjengr/probe_basic/releases/...taller-0.4.0.runthen copied my configuration back into the directory. So far everything runs flawlessly except for one thing. When I load a program, the following error message appears:
  File "/home/roger/.local/lib/python2.7/site-packages/qtpyvcp/widgets/display_widgets/vtk_backplot/vtk_backplot.py", line 428, in load_program
    self.load(fname)
  File "/home/roger/.local/lib/python2.7/site-packages/qtpyvcp/widgets/display_widgets/vtk_backplot/base_backplot.py", line 70, in load
    result, seq = gcode.parse(filename, self.canon, unitcode, initcode)
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe4' in position 14: ordinal not in range(128)
who can tell me what this error message means?
Last edit: 18 Aug 2021 11:54 by Roger S.
18 Aug 2021 13:18 #218085 by harindugamlath
Replied by harindugamlath on topic Probe Basic, error after reinstallation
Its 4.0 right? seems like something is broken. was planning to do the same. Let's wait till the developers see.
19 Aug 2021 11:43 #218156 by Roger S
22 Aug 2021 12:47 - 22 Aug 2021 12:48 #218419 by harindugamlath
I just did the same exact installation as you. It works perfectly fine. Had issues with the screen saver on debian though.
I've heard backplot in 4.0 is different from other versions just guessing something got messed up with your previous config.
Try a reinstall if you can and run probe basic one time before copying your configs.
I was goint to direct you to the freenode where you will get a better answer but freenode webchat on probe basic seems down? or freenode is down. Guess we'll have to wait someone to show up.
Last edit: 22 Aug 2021 12:48 by harindugamlath.
22 Aug 2021 13:08 #218422 by TurBoss
Replied by TurBoss on topic Probe Basic, error after reinstallation
we moved to libera.chat #qtpyvcp
thanks!
22 Aug 2021 13:44 #218426 by Lcvette
Replied by Lcvette on topic Probe Basic, error after reinstallation
in your INI file for start up program you need to ahev blank.ngc specified to load at startup.  check and verify it directs to the file via the correct path.
22 Aug 2021 13:46 #218427 by TurBoss
maybe is some local character in the filename like ñ or ç
25 Aug 2021 12:11 #218721 by Roger S
Replied by Roger S on topic Probe Basic, error after reinstallation
Many thanks for your responses.
- the blank.ngc is loaded correctly
- if i take a new configuration and run it in simulation mode, i get the same error
So I am not spared a new installation?
25 Aug 2021 12:23 - 25 Aug 2021 12:26 #218722 by Lcvette
If blank.ngc is loading correctly without error, then it would seem the issue lies in your file you are attempting to load, can you share that file here so we can test on our installations as well?
Last edit: 25 Aug 2021 12:26 by Lcvette.
25 Aug 2021 12:40 #218723 by Roger S
I've tried different files
File Name: 2.1Lakeside0.5mm.ngc
File Size:55 KB
Moderators: KCJ, Lcvette
Time to create page: 0.199 seconds
