Add math calculator to GUI
  • aleksamc
  • aleksamc's Avatar Topic Author
  • Platinum Member
  • Platinum Member
20 Aug 2021 15:23 - 20 Aug 2021 15:59 #218272 by aleksamc
Add math calculator to GUI was created by aleksamc
I maid some GUI from tutorial some times ago.
There is  MDI tutorial
, where explained how to make some keyboard for mdi.
I would like in my GUI to add some functionality to such keyboard - to add math function buttons:
add, subtract, divide and mux.
Here is my python file.
File Name: mainwindow...08-20.py
File Size:4 KB
There is functions
def WriteJogValue(self,button): if len(self.displayLabel.text()) >0: text = float(self.displayLabel.text()) if text > 0 or test <0: self.jogval.setValue(text) else: self.jogval.setValue(0) self.displayLabel.clear()
In such function I need to include such functionality for calculator:
self.displayLabel.text()[code] - is a text from screenwhere I need to get line:
567/2 (for example)
and to return back to this screen integer result: 283 or 285 or 283.5 (and in future programs to convert this float to integer)
How to make such thing?
I Think, I should do it with regular expressions:
[/code]
Af = re.match(r".*A\s*([\d\.,]+)", line)
In such example I find number after A and before space. It's hard to me to understand regular expressions. I don't understand them.
Last edit: 20 Aug 2021 15:59 by aleksamc.
21 Aug 2021 07:48 #218323 by BigJohnT
Replied by BigJohnT on topic Add math calculator to GUI
For simple equations you can use a function like this
#!/usr/bin/python3
def numeric(equation):
	if '+' in equation:
		y = equation.split('+')
		x = int(y[0])+int(y[1])
	elif '-' in equation:
		y = equation.split('-')
		x = int(y[0])-int(y[1])
	elif '/' in equation:
		y = equation.split('/')
		x = int(y[0])/int(y[1])
	elif '*' in equation:
		y = equation.split('*')
		x = int(y[0])*int(y[1])
	return x
test = input('Enter Simple Math ')
result = numeric(test)
print(result)
JT
The following user(s) said Thank You: aleksamc
  • aleksamc
  • Platinum Member
  • Platinum Member
21 Aug 2021 10:41 #218329 by aleksamc
Replied by aleksamc on topic Add math calculator to GUI
Thank you very mach, BigJohnT.
You helped me much.
Your program is very short and clear.
22 Aug 2021 07:09 #218408 by BigJohnT
A better example that works with negative numbers and floats and when the enter key is pressed it does the calculation.
#!/usr/bin/python3
import sys
from PyQt5.QtWidgets import (QApplication, QMainWindow, QLineEdit,
	QVBoxLayout, QLabel, QWidget, QFrame)
from PyQt5.QtGui import QIcon
class Window(QMainWindow):
	def __init__(self):
		super().__init__()
		self.setGeometry(50, 50, 350, 100) # X, Y, Width, Height
		self.setWindowTitle("PyQT5 Math Example!")
		central_widget = QWidget() # define central widget
		layout = QVBoxLayout() # define layout
		self.entry = QLineEdit()
		layout.addWidget(self.entry)
		self.lbl = QLabel(self)
		self.lbl.setFrameShape(QFrame.Box)
		self.lbl.setText('Enter a Simple Equation')
		layout.addWidget(self.lbl)
		central_widget.setLayout(layout) # add layout to central widget
		self.setCentralWidget(central_widget) # set QMainWindow layout
		# do the calc function when enter is pressed
		self.entry.returnPressed.connect(self.calc)
		self.show() # show the window
	def calc(self):
		equation = self.entry.text()
		if '+' in equation:
			x = self.str2number(y[0])+self.str2number(y[1])
			x = self.str2number(y[0])-self.str2number(y[1])
			x = self.str2number(y[0])/self.str2number(y[1])
			x = self.str2number(y[0])*self.str2number(y[1])
		else:
			x = 'Invalid Equation'
		self.lbl.setText(str(x))
	def str2number(self, num):
		if num.isdigit():
			return int(num)
		elif num.startswith('-') and num[1:].isdigit():
			return int(num)
		else:
			return float(num)
if __name__ == '__main__':
	app = QApplication(sys.argv)
	GUI = Window()
	sys.exit(app.exec_())
JT
22 Aug 2021 07:10 #218409 by BigJohnT
Screenshot.
JT
  • aleksamc
  • Platinum Member
  • Platinum Member
22 Aug 2021 13:05 #218420 by aleksamc
I used your first example for calcs.
    def Calc(self, button):
            equation = self.displayLabel.text()
            x=0
            if '+' in equation:
                x = float(y[0])+float(y[1])
                x = float(y[0])-float(y[1])
                x = float(y[0])/float(y[1])
                x = float(y[0])*float(y[1])
            self.displayLabel.setNum(x)
For writing equation I use such function (from example)
    def numKeyboard(self, button):
        text = self.displayLabel.text() # copy the label text to the variable
        if len(text) > 0: # if there is something in the label
            text += button.text() # add the button text to the text variable
        else: # if the label is empty
            text = button.text() # assign the button text to the text variable
        self.displayLabel.setText(text) # set the text in label
"New forum editor is very good but return me back old one)))"
22 Aug 2021 15:31 #218436 by rodw
Replied by rodw on topic Add math calculator to GUI
Also look at the Python eval() statement to parse your input...
realpython.com/python-eval-function/
[code]>>> # Arithmetic operations
>>> eval("5 + 7")
12
>>> eval("5 * 7")
35
>>> eval("5 ** 7")
78125
>>> eval("(5 + 7) / 2")
6.0
>>> import math
>>> # Area of a circle
>>> eval("math.pi * pow(25, 2)")
1963.4954084936207
>>> # Volume of a sphere
>>> eval("4 / 3 * math.pi * math.pow(25, 3)")
65449.84694978735
>>> # Hypotenuse of a right triangle
>>> eval("math.sqrt(math.pow(10, 2) + math.pow(15, 2))")
18.027756377319946
[/code]
  • aleksamc
  • Platinum Member
  • Platinum Member
22 Aug 2021 15:42 #218437 by aleksamc
Rodw, I currently try to solve such problem
I don't understand why logic statement
if (('+' or '-' or '*' or '/') in text) and ((button.text() == '+') or (button.text() == '-') or (button.text() == '*') or (button.text() == '/')):
works only partly like this:
if (('+' or '-' or '*' or '/') in text) and ((button.text() == '+') ....):
And you solve my problem complitly from other side!
22 Aug 2021 15:55 #218438 by BigJohnT
Just so you know eval() can be used for some bad things like wiping out your hard drive so use with caution.
JT
23 Aug 2021 15:56 #218549 by rodw
JT
Well, you can guard against that
stackoverflow.com/questions/35804961/pyt...and-attribute-access
Moderators: KCJ, Lcvette
Time to create page: 0.131 seconds
