Add math calculator to GUI
- BigJohnT
- Thank you received: 994
23 Aug 2021 17:50 #218558
by BigJohnT
Replied by BigJohnT on topic Add math calculator to GUI
For simple math like the OP asked about 567/2 (for example) it seems easier to understand and use the code I posted...
JT
JT
- anfänger
- Thank you received: 271
25 Aug 2021 02:14 #218682
by anfänger
Replied by anfänger on topic Add math calculator to GUI
For what do you need the calculator?
For setting offsets there is a widget where you can use simple math terms.
- aleksamc
- Thank you received: 67
25 Aug 2021 14:51 #218730
by aleksamc
Replied by aleksamc on topic Add math calculator to GUI
I used eval function, it works grate.
Firstly I used BigJohnT solvement. But I saw there a little bit problems, if to write 45/2*3, it will count only first two elements.
Then I started to write code that if I write second time operational char, it make counting of previous.
But I didn't finished it, it somehow worked only for one part of it, as I wrote previusly in my post. I'm not experianced in python, and it tab/spaces logic separation irritates me. I sudied C++ and there is { everythin here } syntax I think very nice. So, pissibly python thought that in the line is and of page and my logic, I don't know.
Then "eval()" solved this problem with easiness.
I use this function only for counting in simple calc to not to count in head, very comfortable, I think.
I almost finished cnc machine for retrofit with MESA and QTpyvcp. When I'll make video, I'll show it at "Show your stuff".
- Thank you received: 4154
25 Aug 2021 16:08 #218734
Replied by rodw on topic Add math calculator to GUI
Great it works for you. I'm not so good with Python either. With Python, I always assume the feature I need already exists, so I do a bit of Googling and usually it does. eval was no exception. Years ago I had code for a recursive calculator in C which was neat. I wish I still had it.I used eval function, it works grate.
Moderators: KCJ, Lcvette
Time to create page: 0.143 seconds
