(UPDATE) QtPyVCP hal pins
- spumco
- Thank you received: 905
04 Oct 2021 03:07 #222162
by spumco
Action Button names - pins? was created by spumco
Struggling with setting up LCNC and waiting for some guidance on other questions, so I figured I'd try something simple.
2.8.2, QtPyVCP & Probe Basic installed and working.
I have encoders connected to my feed/speed/vel overrides, all three work, and the screen sliders move when I twiddle the knobs.
All three have built-in switches which are connected to Mesa pins. I can see all three working in HAL Show.
I'd like to have the switches reset the overrides just like the PB screen buttons to the right of the sliders.
Opened up QT Designer and found that the FRO reset action button is named machine.feed-override.reset. But I can't find that pin name or whatever it is in the halcmd pin/signal list.
I get the feeling that QtPyVCP bypasses normal channels...? How does that action button 'talk' to LCNC, and is there a way for me to connect my switch to that function?
Having a hard time troubleshooting this because I think my QtPyVCP installation - while it appears to be working - may not have gone according to plan. I've read through the tutorial(s) and various threads and none of the config.yml, sims, PB-specific HAL files are under linuxcnc/configs.
There's a bunch of stuff under .local/lib/python2.7/site-packages/home/MILL/linuxcnc/configs/sim.qtvcp/, but none of the sims appear in the LCNC menu. Did I do something silly during installation?
Thanks,
Ralph
Thanks,
Ralph
- TurBoss
- Thank you received: 81
04 Oct 2021 08:03 #222171
by TurBoss
Replied by TurBoss on topic Action Button names - pins?
hello,
you can add
hal:
provider: qtpyvcp.plugins.exported_hal:ExportedHal
to your config.yaml or custom_config.yaml where the data_plugins got initialized
then pins should be visible from halshow tool
hope it helps
you can add
hal:
hope it helps
- spumco
05 Oct 2021 01:07 #222236
by spumco
Replied by spumco on topic Action Button names - pins?
Thanks, I'll have a go at it once I find the yaml files.
- TurBoss
05 Oct 2021 06:22 - 05 Oct 2021 06:27 #222254
by TurBoss
Hello,
If you are doing modifications to probebasic
is a good idea to have a probebasic copy of the source files in some work directory
backup your changes
you can git clone the project by running:
python2
git clone github.com/kcjengr/probe_basic.git
cd probe_basic/
python -m pip install -e .
or python3
git clone -b python3 github.com/kcjengr/probe_basic.git
cd probe_basic/
python3 -m pip install qtpyvcp
python3 -m pip install -e .
then you could find sample configs under probe_basic/config/probe_basic
and you could also back copy your modifications from .local/...
yaml files can be on the work_dir/probe_basic/probe_basic/probe_basic.yml
backup your changes
python2
cd probe_basic/
or python3
cd probe_basic/
Last edit: 05 Oct 2021 06:27 by TurBoss.
- spumco
08 Oct 2021 01:39 #222509
by spumco
Finally got back to the point where I have a mostly working computer and could try this.
Added the statement from your post to custom_config.yml (in my test copy config) and LCNC terminated with error.
Error log attached. Should I have added it somewhere else, or some other way in the file?
Thx,
R
Thx,
R
- Joco
- Thank you received: 327
08 Oct 2021 06:53 - 08 Oct 2021 06:54 #222524
by Joco
Replied by Joco on topic Action Button names - pins?
Probably need to post the yaml file for inspection.
Also in that log I saw
Which suggests something re the a directory being referenced isn't quite right.
/usr/bin/linuxcnc: line 290: cd: $'/home/MILL/linuxcnc/configs\n.\nBasic': No such file or directoryWhich suggests something re the a directory being referenced isn't quite right.
Last edit: 08 Oct 2021 06:54 by Joco.
- spumco
08 Oct 2021 21:02 #222584
by spumco
yaml file custom_config.yml attached as suggested. Renamed to .txt so I could attach.
- TurBoss
09 Oct 2021 00:18 - 09 Oct 2021 00:18 #222614
by TurBoss
this is the yaml file that includes all pb features
notice the data_plugins section
hal and others are there
since we are overriding data_plugins: from custom_config.yml
we need to add the plugins used to be there like status tooltable persitent data manager
hope it helps
hope it helps
Last edit: 09 Oct 2021 00:18 by TurBoss.
- spumco
09 Oct 2021 01:21 - 09 Oct 2021 03:07 #222617
by spumco
That did the trick!
Last question for now... I found the qtpyvcp pin section, but the FRO reset and RRO reset don't appear to be linked to anything?
EDIT
TO be more specific, I found pin halui.feed-override.value in HALshow. The value responds to the PB screen slider, but it isn't linked to a signal that I can see anywhere.
My intention/desire is to have my FRO/SRO/RRO encoders control or override the screen sliders, and have the sliders respond to the encoders. I would also like the encoder NO switch duplicate the screen override reset switch.
I don't want to change any of the screen elements or functions, so I don't think I need QtPyVCP designer.
But I don't get how to interact with PB.
EDIT
Last edit: 09 Oct 2021 03:07 by spumco. Reason: edited for more detail
- Joco
09 Oct 2021 05:30 - 09 Oct 2021 06:09 #222624
by Joco
Other than HAL pins the either qtpyvcp or a GUI (PB in this case) explicitly expose there is no specific connection bweteen the HAL pins you see and the UI.
HAL is a way of setting various states/values within the linuxcnc "machine" from hardware. Hence H(ardware) A(abstraction) L(ayer). As you may have seen you can do some pretty complex things with and within HAL.
So, if you use a pin such as the halui.feed-override.value you are changing values inside the linuxcnc engine. If the UI is representing these values corrcetly via widgets then those widgets will automatically change to represent what is happening to the underlying values.
Now in the case of the reset switch those pins are INPUT pins only. That means you can connect a h/w button of someform to them to trigger the reset. The onscreen button may or maynot react at the same time. I can't recall. It's been to long since I wrote and tested that code in the framework.
Hopefully a little helpful.
Cheers - J.
Cheers - J.
Last edit: 09 Oct 2021 06:09 by Joco.
Moderators: KCJ, Lcvette
Time to create page: 0.099 seconds
