Probe basic manual tool change
19 Nov 2021 14:08 #226983 by icy
Probe basic manual tool change was created by icy
Hello,
i am struggling with probe basic and the manual tool change.
If i select a tool and go then to touch of current tool, the sensor will be touched 2 times and the value is put in the tool table.
i have adapted all values as shown here
, but i have a problem.
Following situation: i want to mill an aluminum plate with 2 different tools.
Load Tool 1 and make an "touch off current tool", than i set z to 0 at the top of the workpiece. Everything was god at this point, but now the spindle stops and i put the new tool in, and do the measurement, but now the tool did not touch the surface anymore.
I ve tried some ways to load and measure the tool, but i am getting the same problem each time.
If i try the measurement some times, my tool is getting longer and longer , starting at 44mm, up to 230mm at the end.
Best regards
Chris
19 Nov 2021 18:46 #227014 by MoshKopp
Replied by MoshKopp on topic Probe basic manual tool change
have you give the right value for spindlelength?
20 Nov 2021 10:05 #227066 by icy
Replied by icy on topic Probe basic manual tool change
Spindle length not, but i have not found anything about the length. I have only set in the spindle zero ( touching the clamping nut and the tool sensor )
20 Nov 2021 10:21 #227069 by MoshKopp
Thats what i mean. Hmm ok.
Can you Post your file for M6 remap?
22 Nov 2021 13:36 #227295 by icy
at the moment i have no remap in the ini file.
If i put the zero spindle positive ( in my case 119.85mm ), than the tool length will be too large , if i post the spindle zero negative , that the too length value is correct, but the measurement script did not spot automatically. I have tried a lot of configurations, maybe you have an idea ?
File Name: my_LinuxCN...1-22.hal
File Size:10 KB
File Name: my_LinuxCN...1-22.ini
File Size:6 KB
File Name: postgui_call_list.hal
File Size:0 KB
22 Nov 2021 16:05 #227307 by icy
I found another problem, if i try to change an tool mit T1 M6, nothing happen ( no Change tool window) and an script is hanging around ( i have to Stop the script with the stop button.
23 Nov 2021 00:01 #227344 by andypugh
Replied by andypugh on topic Probe basic manual tool change
This sounds like you have no connection between the iocontrol.0.tool-change and iocontrol.0.tool-changed HAL pins.
These are the "handshake" that indicates that the tool change is finished.
25 Nov 2021 08:51 #227566 by ikkuh
Replied by ikkuh on topic Probe basic manual tool change
or an error in your remapping.
If you use for example the gmocccapy M6 remap routines you need to edit some python files because of python version problems.
My edited version for a recent python 3 version can be found there: git.cnckloon.nl/PeterT/qtDragonNew/src/b...h/buttonBoard/python
25 Nov 2021 15:34 #227570 by TooTall18T
Replied by TooTall18T on topic Probe basic manual tool change
Which version of the M600 do you use?
The configuration of version 1 and 2 is different.
The video was for version 1 .
Moderators: KCJ, Lcvette
Time to create page: 1.756 seconds
