Hello,
i am struggling with probe basic and the manual tool change.
If i select a tool and go then to touch of current tool, the sensor will be touched 2 times and the value is put in the tool table.
i have adapted all values as shown here
, but i have a problem.
Following situation: i want to mill an aluminum plate with 2 different tools.
Load Tool 1 and make an "touch off current tool", than i set z to 0 at the top of the workpiece. Everything was god at this point, but now the spindle stops and i put the new tool in, and do the measurement, but now the tool did not touch the surface anymore.
I ve tried some ways to load and measure the tool, but i am getting the same problem each time.
If i try the measurement some times, my tool is getting longer and longer , starting at 44mm, up to 230mm at the end.
Best regards
Chris
