Probe basic manual tool change
4 years 11 months ago #227344 by andypugh
This sounds like you have no connection between the iocontrol.0.tool-change and iocontrol.0.tool-changed HAL pins.
These are the "handshake" that indicates that the tool change is finished.
4 years 11 months ago #227566 by ikkuh
I found another problem, if i try to change an tool mit T1 M6, nothing happen ( no Change tool window) and an script is hanging around ( i have to Stop the script with the stop button.
or an error in your remapping.
If you use for example the gmocccapy M6 remap routines you need to edit some python files because of python version problems.
My edited version for a recent python 3 version can be found there: git.cnckloon.nl/PeterT/qtDragonNew/src/b...h/buttonBoard/python
4 years 11 months ago #227570 by TooTall18T
Which version of the M600 do you use?
The configuration of version 1 and 2 is different.
The video was for version 1 .
Moderators: KCJ, Lcvette
Time to create page: 0.300 seconds
