{SOLVED} Latest Version Install Failure
  • Donb9261
  • Donb9261's Avatar Topic Author
  • Elite Member
  • Elite Member
03 Jan 2022 15:35 - 05 Jan 2022 04:50 #230683 by Donb9261
{SOLVED} Latest Version Install Failure was created by Donb9261
LInux Mint 20.2 Cinnamon
Installed 2.9 Premept
Error happens when trying to load qtpyvcp or even testing if it is installed correctly...
don@don-Mint:~$ qtpyvcp -h
  File "/home/don/.local/bin/qtpyvcp", line 8, in <module>
    sys.exit(main())
  File "/home/don/.local/lib/python3.8/site-packages/qtpyvcp/app/__init__.py", line 72, in main
    from qtpyvcp.utilities.opt_parser import parse_opts
  File "/home/don/.local/lib/python3.8/site-packages/qtpyvcp/utilities/opt_parser.py", line 56, in <module>
    from linuxcnc import ini
ModuleNotFoundError: No module named 'linuxcnc'
Same error if I try to use the call from LCNC. LCNC shuts down with the same error.
Followed all procedures.
LCNC working with all other sims and profiles.
Last edit: 05 Jan 2022 04:50 by Donb9261.
  • Donb9261
  • Elite Member
  • Elite Member
03 Jan 2022 15:50 #230686 by Donb9261
Replied by Donb9261 on topic Latest Version Install Failure
Tried a 4th re-install of qtpyvcp and tried qtpyvcp -h.
don@don-Mint:~/qtpyvcp$ qtpyvcp -h
File "/home/don/.local/bin/qtpyvcp", line 11, in <module>
load_entry_point('qtpyvcp', 'console_scripts', 'qtpyvcp')()
File "/home/don/qtpyvcp/qtpyvcp/app/__init__.py", line 72, in main
File "/home/don/qtpyvcp/qtpyvcp/utilities/opt_parser.py", line 64, in <module>
ImportError: cannot import name 'ini' from 'linuxcnc' (unknown location)
  • Moderator
  • Moderator
03 Jan 2022 17:11 #230692 by tommylight
Replied by tommylight on topic Latest Version Install Failure
Use Debian or MX Linux, Mint 20 does not do well with QtPy anything as it uses an older version by default.
  • Donb9261
  • Elite Member
  • Elite Member
03 Jan 2022 17:57 #230697 by Donb9261
I would but Debian does not work on install without a wired cable.
I had Mint 19 working fine. Just trying to get 20 working.
MX LInux?
  • Donb9261
  • Elite Member
  • Elite Member
03 Jan 2022 17:59 #230698 by Donb9261
Do you have a working MX with LCNC RT and QtPyVCP?
  • Moderator
  • Moderator
03 Jan 2022 18:37 #230702 by tommylight
03 Jan 2022 18:43 #230704 by spumco
Replied by spumco on topic Latest Version Install Failure
Tommy's suggestion of using the Debian version with the non-free drivers worked for a wifi installation for me.
I still went back to MX21, but if you're set on Debian you might have a go with the non-free ISO.
04 Jan 2022 03:43 #230737 by rodw
Replied by rodw on topic Latest Version Install Failure
You could follow these instructions
www.qtpyvcp.com/install/bullseye.html
The problem with mint is they use an old version of Python3 and Python 3.9 or higher is required. I could not get it sorted out so moved to Debian 11 using the same method described above.
  • Donb9261
  • Elite Member
  • Elite Member
04 Jan 2022 08:05 #230763 by Donb9261
Hey Rod,
Thanks. So far I have tried MX 19.4 as Tommy said, but I cannot launch editvcp. This experience was not what it was last time I tried to install QtPyVCP. It was a challenge then but I was able to overcome all the hurdles.
Is it possible that by default Python3 in MX 19.4 is 3.7?
I hate upgrading to 3.9 if it breaks everything.
Regardless, I tried Debian 11 but was unable to determine which non-free distro to choose.
Do you have link to a solid distro that includes all the wifi drivers so I can get a solid install without having to wire up?
04 Jan 2022 17:48 #230810 by spumco
cdimage.debian.org/images/unofficial/non...nfree/amd64/iso-dvd/
This worked for me and a reluctant wifi dongle.
Moderators: KCJ, Lcvette
Time to create page: 0.138 seconds
