{SOLVED} Latest Version Install Failure
- Donb9261
- Thank you received: 103
03 Jan 2022 21:35 - 05 Jan 2022 10:50 #230683
by Donb9261
{SOLVED} Latest Version Install Failure was created by Donb9261
LInux Mint 20.2 Cinnamon
Installed 2.9 Premept
Error happens when trying to load qtpyvcp or even testing if it is installed correctly...
don@don-Mint:~$ qtpyvcp -h
File "/home/don/.local/bin/qtpyvcp", line 8, in <module>
sys.exit(main())
File "/home/don/.local/lib/python3.8/site-packages/qtpyvcp/app/__init__.py", line 72, in main
from qtpyvcp.utilities.opt_parser import parse_opts
File "/home/don/.local/lib/python3.8/site-packages/qtpyvcp/utilities/opt_parser.py", line 56, in <module>
from linuxcnc import ini
ModuleNotFoundError: No module named 'linuxcnc'
Same error if I try to use the call from LCNC. LCNC shuts down with the same error.
Followed all procedures.
LCNC working with all other sims and profiles.
sys.exit(main())
Last edit: 05 Jan 2022 10:50 by Donb9261.
- Donb9261
03 Jan 2022 21:50 #230686
by Donb9261
Replied by Donb9261 on topic Latest Version Install Failure
Tried a 4th re-install of qtpyvcp and tried qtpyvcp -h.
don@don-Mint:~/qtpyvcp$ qtpyvcp -h
File "/home/don/.local/bin/qtpyvcp", line 11, in <module>
load_entry_point('qtpyvcp', 'console_scripts', 'qtpyvcp')()
File "/home/don/qtpyvcp/qtpyvcp/app/__init__.py", line 72, in main
File "/home/don/qtpyvcp/qtpyvcp/utilities/opt_parser.py", line 64, in <module>
ImportError: cannot import name 'ini' from 'linuxcnc' (unknown location)
- Thank you received: 7485
03 Jan 2022 23:11 #230692
Replied by tommylight on topic Latest Version Install Failure
Use Debian or MX Linux, Mint 20 does not do well with QtPy anything as it uses an older version by default.
- Donb9261
03 Jan 2022 23:57 #230697
by Donb9261
I would but Debian does not work on install without a wired cable.
I had Mint 19 working fine. Just trying to get 20 working.
MX LInux?
MX LInux?
- Donb9261
03 Jan 2022 23:59 #230698
by Donb9261
Do you have a working MX with LCNC RT and QtPyVCP?
04 Jan 2022 00:37 #230702
- spumco
- Thank you received: 905
04 Jan 2022 00:43 #230704
by spumco
Replied by spumco on topic Latest Version Install Failure
Tommy's suggestion of using the Debian version with the non-free drivers worked for a wifi installation for me.
I still went back to MX21, but if you're set on Debian you might have a go with the non-free ISO.
- Thank you received: 4149
04 Jan 2022 09:43 #230737
www.qtpyvcp.com/install/bullseye.html
The problem with mint is they use an old version of Python3 and Python 3.9 or higher is required. I could not get it sorted out so moved to Debian 11 using the same method described above.
Replied by rodw on topic Latest Version Install Failure
You could follow these instructionsDo you have a working MX with LCNC RT and QtPyVCP?
- Donb9261
04 Jan 2022 14:05 #230763
by Donb9261
Hey Rod,
Thanks. So far I have tried MX 19.4 as Tommy said, but I cannot launch editvcp. This experience was not what it was last time I tried to install QtPyVCP. It was a challenge then but I was able to overcome all the hurdles.
Is it possible that by default Python3 in MX 19.4 is 3.7?
I hate upgrading to 3.9 if it breaks everything.
Regardless, I tried Debian 11 but was unable to determine which non-free distro to choose.
Do you have link to a solid distro that includes all the wifi drivers so I can get a solid install without having to wire up?
- spumco
04 Jan 2022 23:48 #230810
by spumco
cdimage.debian.org/images/unofficial/non...nfree/amd64/iso-dvd/
This worked for me and a reluctant wifi dongle.
Moderators: KCJ, Lcvette
Time to create page: 0.285 seconds
