Probe Basic Configuration
4 years 6 days ago #255081 by brandon0112
Hi All,
This thread was the only one I could find that addressed this A axis DRO issue in PB. I just recently did a fresh install of lcnc 2.9_pre0 and PB using joco's script. I also installed this on the linked Bullseye iso from that script.
Has anyone else run into this problem again since the original post in August? I am still experiencing this issue even after trying the fix that charleyann found. Additionally, when I changed the axis display rule from axes to joints to try the fix, I was not allowed to change it back to axes.
Any help would be greatly appreciated!
File Name: BrandonCNC...Axis.ini
File Size:7.39 KB
3 years 11 months ago #256322 by brandon0112
Bump. Really hoping someone has some thoughts as this is still an issue for me. Thanks
3 years 11 months ago #256328 by tommylight
You can try contacting them on the IRC, they have their channel wtitten somewhere on github i think.
3 years 11 months ago #256355 by Lcvette
Replied by Lcvette on topic Probe Basic Configuration
I will take a look in a few and aee if i can suss out the issue.
3 years 11 months ago #256357 by charleyann
I made a small change to me original fix for the axis_display_rule on the gui_axis_display_widget
Change the channel to: "status:joints" and set the type to int.
Set the expression to 0 for the XYZ display, 1 for XYZA and 2 for XYZAB
Attached is a screen clip of the settings.
The following user(s) said Thank You: spumco, brandon0112
3 years 9 months ago #260983 by brandon0112
Big thanks, charleyann! Changing the expression brought the A axis DRO out for me!
Moderators: KCJ, Lcvette
Time to create page: 0.268 seconds
