Probe Basic Rack based ATC
4 years 3 months ago #247651 by tommylight
Wishing you a quick and painless recovery.
The following user(s) said Thank You: P1-Engineering
4 years 3 months ago #247668 by Lcvette
Replied by Lcvette on topic Probe Basic Rack based ATC
As Spumco mentioned, I worked on the linear ATC for a while but have not returned to it yet. once 2.9 is completely sorted my plan is to finish up several things in PB for mill and various ATC types along with lathe and some much needed updating there. it just seems to be a difficult situation until there is a simple release and update method for the py3 conversion. once its done it will be fantastic i have no doubt and easier then ever to update LCNC and probe basic will then likely become a deb type install which should simplify things for everyone, but as it stands i spend more time trying to help people figure out installation issues than functionality upgrades.
4 years 3 months ago #247719 by P1-Engineering
Looking forward to it!.
Seeing Probe Basic had me convinced on trying the LinuxCNC route.
Thank you for all the hard work. Together with the Klipper, Mainsail, interface these open source projects have impressed me a lot.
If needed I can help with the rack-based ATC. I have a fully functional macro already which has been flawless in a production environment, but it's for EdingCNC
It's written in standard G-code and uses a list of variables to store the XYZ coordinates for every pocket. Also has breakage control built in.
I will convert this to LinuxCNC anyway to see if I can get it working, to learn the principles of LinuxCNC.
The following user(s) said Thank You: Lcvette
4 years 3 months ago #247720 by P1-Engineering
Thank you Tommy. It's just a matter of time luckily, just have to be patient and keep myself busy by learning new things.
2 years 11 months ago #285480 by udoS
Replied by udoS on topic Probe Basic Rack based ATC
@P1-Engineering
Hi, has anyone made some progress or implementation for the Rack-ATC in Probe-Basic by now;
Best Regards
udoS
2 years 11 months ago #285604 by CNC_ANDI
Replied by CNC_ANDI on topic Probe Basic Rack based ATC
Follow
Moderators: KCJ, Lcvette
Time to create page: 0.369 seconds
