Install QtPyVCP RPI4 kernel PREEMPT_RT 64 bits
- rbobey1989
- Thank you received: 33
27 Jul 2022 11:15 #248406
by rbobey1989
Install QtPyVCP RPI4 kernel PREEMPT_RT 64 bits was created by rbobey1989
Hello, I have been doing some tests with qtpyvcp on the Raspberry RPI4 model B, linuxcnc 2.9 master branch and kernel PREEMPT_RT 64 bits, everything works great, I have installed qt 5.15.2 and pyqt5, I have verified the installation of qtpyvcp with the commands:
qtpyvcp -i
qtpyvcp -h
and all good, I have executed the installation script of qt designer plugins as follows:
cd ~/dev/qtpyvcp/pyqt5designer/Qt5.15.2-64bit/python3.9/
sudo ./install.sh
editing install.sh
x86_64 to aarch64 in the script_path
my problem is the following, the linuxcnc widgets are not loaded in qtdesigner, it gives me a widgets failed error even though the libpyqt5.so file is copied to:
usr/lib/x86_64-linux-gnu/qt5/plugins/designer
qtdesigner recognizes it, but as failed widgets.
By the way, the qtpyvcp installation process followed is the one described in:
www.qtpyvcp.com/install/index.html
So if possible if someone can shed some light on this case I would appreciate it, regards
qtpyvcp -i
qtpyvcp -h
sudo ./install.sh
editing install.sh
- TurBoss
- Thank you received: 81
27 Jul 2022 11:51 - 27 Jul 2022 14:08 #248410
by TurBoss
Replied by TurBoss on topic Install QtPyVCP RPI4 kernel PREEMPT_RT 64 bits
Hello
libpyqt5.so is built for x86 it cant run on the pi
To get widgets in designer you may need to build pyqt5libs for this from source
Details can be found here github.com/kcjengr/qtpyvcp/blob/master/p...building_libpyqt5.md
Should work on the pi but i have not tested
edit: details are for python2 but can be adapted to work on python2
Last edit: 27 Jul 2022 14:08 by TurBoss.
- elovalvo
- Thank you received: 127
28 Jul 2022 06:00 #248509
by elovalvo
Replied by elovalvo on topic Install QtPyVCP RPI4 kernel PREEMPT_RT 64 bits
Similarly to what is reported here
www.qtpyvcp.com/install/bullseye.html
you should run these commands
sudo ./install.sh
and then fix everything with
cp -r ~/dev/qtpyvcp/linuxcnc ~/
sudo ./install.sh
- ftree
- Thank you received: 10
28 Jul 2022 13:48 - 28 Jul 2022 14:23 #248534
by ftree
Replied by ftree on topic Install QtPyVCP RPI4 kernel PREEMPT_RT 64 bits
I thought libpyqt5.so was in python3-pyqt5
/usr/lib/aarch64-linux-gnu/qt5/plugins/designer/libpyqt5.so
packages.debian.org/bookworm/arm64/python3-pyqt5/filelist
Could always look at altering the debian/rules to make just libpyqt5.so from source to latest packaging.
# pyqt 5.15.7+dfsg-1
git clone https://salsa.debian.org/python-team/packages/pyqt5.git
cd pyqt5
git checkout 49d94553
mk-build-deps --install --tool='apt-get -o Debug::pkgProblemResolver=yes --yes' debian/control
dch --force-distribution -b -v 5.15.7+dfsg-1 --distribution unstable "built by me"
# maybe alter debian/rules with sed
# fakeroot ./debian/rules binary
dpkg-buildpackage -us -uc -b
Last edit: 28 Jul 2022 14:23 by ftree.
- rbobey1989
31 Jul 2022 20:25 #248754
by rbobey1989
Replied by rbobey1989 on topic Install QtPyVCP RPI4 kernel PREEMPT_RT 64 bits
hello I've been a bit busy although I've managed to make progress on this topic, I've compiled PyQt5 from source, surprise, everything works correctly, or rather almost everything lol, the widgets load without problems and I've followed the qtpyvcp tutorials until it was necessary use GcodeBackplot to my surprise I do not have it inside the widgets, however I used VKBackPlot only as a test but qt_designer does not display it and linuxcnc reports an error or several I imagine it has to do with the version of opengl 3.2 that I should not have, I attach report from linuxcnc, thanks everyone in advance
- TurBoss
31 Jul 2022 21:07 #248755
by TurBoss
Hello,
you can try this
export MESA_GL_VERSION_OVERRIDE=3.3
export MESA_GLSL_VERSION_OVERRIDE=330
you can try this
- elovalvo
12 Aug 2022 16:41 #249602
by elovalvo
I recently recompiled the VTK and I think this version has solved your problem.
The file vtk-9.2.20220811.dev0-cp39-cp39-linux_aarch64.whl can be downloaded from here:
drive.google.com/file/d/1-v3B5zBLeG8blJI...v4t/view?usp=sharing
To install, run from the terminal
pip install ./vtk-9.2.20220811.dev0-cp39-cp39-linux_aarch64.whl
Moderators: KCJ, Lcvette
