Rotary Jog low
- CNC_ANDI
- Thank you received: 31
15 Jan 2023 21:13 #262067
by CNC_ANDI
Rotary Jog low was created by CNC_ANDI
Hello,
i´m using the probe_basic screen....
so i´ve installed now a 4th axis but the jog rate is always 100°/min.
Jog Slider has no effect.
i´ve tryed DEFAULT_ANGULAR_VELOCITY too but it has no effect too.
Thank you for Help.
Thank you for Help.
- Lcvette
- Thank you received: 782
16 Jan 2023 14:09 #262124
by Lcvette
Replied by Lcvette on topic Rotary Jog low
how about the other angular velocity ini settings? maybe post the ini file for us to review. the axis will only move as fast as max settings for the axis and trajectory control allow. not sure on the jog slider control beyond that as i don't have a 4th axis running yet to test with..
- KCJ
- Thank you received: 267
16 Jan 2023 14:22 #262126
by KCJ
Replied by KCJ on topic Rotary Jog low
The angular jog speed percentage is set separate from the linear jog speed percentage.
This is the action for setting the angular jog speed:
www.qtpyvcp.com/actions/machine_actions....lar_speed_percentage
The slider in probe basic is probably only setting the linear jog speed.
Lcvette: Ideally there should be a separate slider for angular jog speed, but you might be able to use one slider so set both linear and angular jog speed.
- Lcvette
16 Jan 2023 14:36 #262128
by Lcvette
good to know! I will have a look at tying them together! I hope to carve out some time to finish my 4th and 5th axis build this week or next week, so this would have popped up for me then
- spumco
- Thank you received: 896
16 Jan 2023 16:28 #262141
by spumco
Replied by spumco on topic Rotary Jog low
Yes, I ran in to this a while back during my first tests of PB.
I believe the fix KCJ or Joco came up with was to create a hidden slider that was tied to the existing jog slider, and linked to the angular jog rate.
- Lcvette
16 Jan 2023 21:03 - 16 Jan 2023 21:04 #262167
by Lcvette
I just pushed an update that adds an angular jog slider on the settings page, it is linked to the main window jog slider so both angular and linear are controlled with the one slider. i plan to find a way to allow the user to link/unlink the two in the future but need to get back on another project for now. as it stand, you can use the setting page angular slider to control just the angular jogging, but if you adjust the main window jog slider, it resynchronizes the two so be aware of that if you need to change angular jog speed independent from linear jog speed. in the interim however at least there is now some control over it albeit not perfect.
Chris
Chris
Last edit: 16 Jan 2023 21:04 by Lcvette.
The following user(s) said Thank You: tommylight, spumco, CNC_ANDI
- CNC_ANDI
17 Jan 2023 19:47 - 17 Jan 2023 19:48 #262265
by CNC_ANDI
Replied by CNC_ANDI on topic Rotary Jog low
Here is my ini file. You can see the rotary velocity an acclereations.
So how can i get this slider?
Can you tell me how can i do this or did you have a manual for that?
Last edit: 17 Jan 2023 19:48 by CNC_ANDI.
- Lcvette
17 Jan 2023 20:19 #262267
by Lcvette
it is in the latest version of probe basic in the py3 version. what version of linuxcnc and probe basic are you using?Here is my ini file. You can see the rotary velocity an acclereations.
- Lcvette
17 Jan 2023 21:42 #262276
by Lcvette
ok just saw you are on linuxcnc 2.8 which is the old py2 version. that version is no longer updatable, our hands are tied because changing anything in the current installer would break it and require dependencies that are no longer available. so we had to move over to the latest python3 version of linuxcnc to continue development.
however, you can install the py2 dev version, and you can still make changes to your own local interface without worry.
the better option would be to move up to linuxcnc 2.9 on on a Debian 11 bullseye install, and the latest version of probe basic which is updated as needed still. from there you could pull any updates from git as required, and in the near future once linuxcnc 2.9 stable is released there will be an installer available for the latest Probe basic with an updater for easier version release updates. unfortunately it is all still hinging on linuxcnc release arriving for that last part to happen.
- CNC_ANDI
18 Jan 2023 08:25 - 18 Jan 2023 09:24 #262324
by CNC_ANDI
I think linuc cnc 2.8.4.... and have installed the probe basic from the website with the installer since 09-2022
I will check it.
Edit: Ok thanks than i will wait for the stable version before i reinstall my system....
I will check it.
Last edit: 18 Jan 2023 09:24 by CNC_ANDI.
Moderators: KCJ, Lcvette
Time to create page: 0.181 seconds
