Probe Basic - keyboard jogging
3 years 8 months ago #265121 by Lcvette
not sure windows files intermingling with linux files is a good idea because of line ending issues.
3 years 8 months ago - 3 years 8 months ago #265136 by spumco
Was planning to use a VM with MX21 to do screen fiddling, not use MS Wordpad. image missing /media/kunena/emoticons/blink.png
I'll look again at gitkraken - all I saw was the $5/month client thing.  There was a free trial I installed previously, but that died after 30 days.
Last edit: 3 years 8 months ago by spumco. Reason: Doh!
3 years 8 months ago #265140 by TurBoss
Hello,
gitkraken is free for opensoure projects
2 years 11 months ago #286229 by tightmopedman9
Has there been any permanent solution found to disable keyboard jogging? I updated to 2.9 a few days ago and almost crashed my machine while editing an ngc file. Since then I've just toggled machine power to prevent an unintentional jog, but I know eventually I'll forget to do that and have a costly mistake...
2 years 11 months ago #286233 by spumco
I've not been able to find anything.
I think the function that connects keyboard strokes to LCNC is called "keybinding."  The python file defines which keys trigger which functions.  There's a bit of a description in the qtvcp section of LCNC's user manual.
I've found plenty of instances of keybinding in various GUI python files on github, but there's nothing in the LCNC 'core' code.
Nor is there anything in either qtpyvcp or probe basic files on GH.  Which tells me that the basic functions - jog, estop, machine-on - are buried deep inside LCNC and not limited to GUI features.  I suspect the GUI keybinding I found are for additional functions.
However....Gmoccapy appears to have an option to turn off keyboard shorcuts and keyboard jogging.  I've no idea how this works, but poking around in the code on GH may prove fruitful.
Failing that, I think the next step is to open a ticket on GH to add the ability to remove all keyboard jogging - or at least see if the LCNC Dev's can explain how to do it.
I'd also like to remove ALL keyboard functions - like machine-on, estop, etc.
2 years 11 months ago #286239 by tightmopedman9
I tried this solution yesterday and it didn't work. I have a feeling it is AXIS specific, but I don't really know enough to know if that is true.
forum.linuxcnc.org/38-general-linuxcnc-q...gging?start=20#62231
Lcvette mentioned something related to numlock. Does toggling numlock turn off keybinding? I don't have a numlock button on my keyboard so I couldn't easily test this.
opl;..
Moderators: KCJ, Lcvette
