Probe Basic - jog slider & status
- spumco
- Thank you received: 905
19 Jan 2023 17:09 #262440
by spumco
Probe Basic - jog slider & status was created by spumco
I was able to connect my MPG & selector to halui.axis.jog-speed so now I've got a physical adjustment for jog speed. Same thing for FRO, SRO, and RRO.
Problem is that while the FRO, SRO, and RRO UI sliders and status DRO's are all responding to external inputs (i.e. move on screen with my encoders), the on-screen jog adjustment does not respond to external inputs.
Even though I have not connected to any of the qtpyvcp exported hal pins the overrides mentioned still work on screen. Nor did I put anything in the post-gui hal file. They just seem to work ok.
I'd like to connect the jog slider as well. How can I do this?
Thanks,
R
Thanks,
R
- Lcvette
- Thank you received: 784
20 Jan 2023 01:31 #262464
by Lcvette
Replied by Lcvette on topic Probe Basic - jog slider & status
- spumco
20 Jan 2023 14:41 #262522
by spumco
Replied by spumco on topic Probe Basic - jog slider & status
Thanks.
Connect to machine.jog.linear-speed-percentage in postgui? Is that pin name exposed to hal like qtpyvcp.rapid-override-reset?
Reason I ask is that I didn't see any qtpyvcp jog related pins exposed in halshow.
- Lcvette
20 Jan 2023 20:32 #262538
by Lcvette
- spumco
20 Jan 2023 22:49 #262552
by spumco
Sorry if I wasn't clear but I've already got the hal pins exported in my custom_config.yml file. Same config as from the post you linked.
That's what I was referring to earlier when I wrote that I can see the qtpyvcp RRO/SRO/MVO reset pins in halshow.
It's the jog slider that doesn't appear to have an exported hal pin connection.
- Lcvette
20 Jan 2023 23:53 #262554
by Lcvette
can you show how you have your other overrides connected? im looking into it but would help to see what you have setup.
- Lcvette
21 Jan 2023 00:08 #262555
by Lcvette
ok so the other overrides are coded and exposed already the jog percentage slider is not, so will need to expose it probably in the back end to make it easy to access, need to see what is needed there to accomplish.
- Lcvette
21 Jan 2023 00:26 #262556
by Lcvette
try this in the postgui hal file, but with your naming for the net input of course, this is just generic:
# *** Set Line Below for ui Jog Slider hal connection ***
net linear-jog-speed-external-input => qtpyvcp.machine.jog.linear-speed-percentage
- spumco
21 Jan 2023 10:24 #262588
by spumco
Thanks, but no joy.
LCNC throws up with 'pin doesn't exist'
Looking at halshow there are only three exposed override-related pins:
qtpyvcp.feed-override.reset
qtpyvcp.rapid-override.reset
qtpyvcp.spindle-override.reset
On the other hand, what I don't understand is if only the xxx.override.reset pins are exposed, why do the RRO/FRO/SRO status dro's displays and sliders follow external inputs?
My (naive) common-sense tells me only the reset function should work as there's no obvious connection between halui.xxx-override.counts (in) ot halui.xxx-override.value (out).
- spumco
21 Jan 2023 10:47 #262591
by spumco
The plot thickens...
It looks like rapid/feed/max-vel/spindle overrides are linked(?) to value changes in machine_actions.py and spindle_actions.py
def _rapid_override_bindOk(value=100, widget=None):
# This will work for any widget
STATUS.task_state.onValueChanged(lambda: _rapid_override_ok(widget=widget))
try:
# these will only work for QSlider or QSpinBox
widget.setMinimum(0)
widget.setMaximum(100)
try:
widget.setSliderPosition(100)
STATUS.rapidrate.onValueChanged(
lambda v: widget.setSliderPosition(v * 100))
except AttributeError:
lambda v: widget.setValue(v * 100))
widget.setValue(100)
rapid_override.set(100)
pass
except:
LOG.exception('Error in rapid_override bindOk')
rapid_override.set.ok = rapid_override.reset.ok = _rapid_override_ok
rapid_override.set.bindOk = rapid_override.reset.bindOk = _rapid_override_bindOk
But the jog-override section of machine_actions.py doesn't appear to have the same 'onValueChanged' functions:
I don't understand python, but it looks like the jog control was written differently than the other overrides.
Warning: Spoiler!
try:
try:
pass
except:
Warning: Spoiler!
def _jog_speed_slider_bindOk(widget): try:# these will only work for QSlider or QSpinBoxwidget.setMinimum(0)widget.setMaximum(100)widget.setValue((jog.linear_speed.getValue() / jog.max_linear_speed) * 100) # jog.linear_speed.connect(lambda v: widget.setValue(v * 100))except AttributeError:pass def _jog_angular_speed_slider_bindOk(widget): try:# these will only work for QSlider or QSpinBoxwidget.setMinimum(0)widget.setMaximum(100)widget.setValue((jog.angular_speed.getValue() / jog.max_angular_speed) * 100) # jog.linear_speed.connect(lambda v: widget.setValue(v * 100))except AttributeError:pass jog.set_linear_speed.ok = jog.set_angular_speed.ok = lambda *a, **k: Truejog.set_linear_speed.bindOk = jog.set_angular_speed.bindOk = lambda *a, **k: True jog.set_linear_speed_percentage.ok = lambda *a, **k: Truejog.set_linear_speed_percentage.bindOk = _jog_speed_slider_bindOk jog.set_angular_speed_percentage.ok = lambda *a, **k: Truejog.set_angular_speed_percentage.bindOk = _jog_angular_speed_slider_bindOk
Moderators: KCJ, Lcvette
Time to create page: 0.190 seconds
