Rapid and Cutting Feedrate
- CNC_ANDI
- Thank you received: 31
14 Mar 2023 17:51 #266680
by CNC_ANDI
Rapid and Cutting Feedrate was created by CNC_ANDI
Hello,
Can I combine the rapid feed rate and the cutting speed?
I don't understand why these two speeds are separate.
If I want to move slowly then I want to control both at the same time.
- spumco
- Thank you received: 905
14 Mar 2023 18:07 #266681
by spumco
Replied by spumco on topic Rapid and Cutting Feedrate
On some machines the rapid rate is extremely fast - too fast for an operator to stop an impending problem.
In these cases it's desirable to permit slowing the rapids down while not affecting the actual cutting feed rate.
The two overrides can't be 'combined', but depending on how you have configured them you can control both with a single input.
How are you currently controlling them?
- robertspark
- Thank you received: 216
14 Mar 2023 18:09 #266682
by robertspark
Replied by robertspark on topic Rapid and Cutting Feedrate
because G0 is very different to G1, G2 and G3 motion.
G0 is a non cutting feedrate to get the tool from A to B as quickly as possible
can you explain what you want to do
- CNC_ANDI
14 Mar 2023 18:53 - 14 Mar 2023 18:57 #266686
by CNC_ANDI
Replied by CNC_ANDI on topic Rapid and Cutting Feedrate
currently i controlling them with the 2 sliders on probe_basic....
but i will install a poti for feedrates and spindlespeed
so i will do one poti for cutting and rapid feedrate and a second poti for the spindlespeed
yes that´s what i mean
Last edit: 14 Mar 2023 18:57 by CNC_ANDI.
- spumco
15 Mar 2023 14:06 #266751
by spumco
Something else to consider - there's usually a maximum value difference between rapid and feed overrides.
FRO can, depending on configuration, be set to a value somewhere between 0 and 150% of programmed feed.
RRO is 0-100%, since you can't go faster than the MAX_VELOCITY of that axis.
If you link the inputs to RRO and FRO together, turning FRO up past 100% won't do anything to the RRO. However, if you have FRO at 150% and then turn it down RRO may follow the decrease and go down below 100%.
Whether you use a pot or an encoder, it may take some fiddling to get both overrides to work as you wish.
I'm using probe basic, and what I've done is keep the RRO and FRO separate. My FRO is controlled by an external encoder, and my RRO is controlled using momentary pushbuttons with pre-set values. I didn't think I'd ever need to adjust rapids to something like 78% or 13.5%... just Fast / Slow / Really Slow.
Works well, and if it sounds useful to you here's a post on using mux4 and Classic Ladder to duplicate.
forum.linuxcnc.org/24-hal-components/479...lassic-ladder#262309
The following user(s) said Thank You: CNC_ANDI
- CNC_ANDI
15 Mar 2023 16:34 #266761
by CNC_ANDI
i don´t have ClassicLadder and mux4.
i will it do just with analog Potis
- Lcvette
- Thank you received: 782
15 Mar 2023 17:46 #266772
by Lcvette
Replied by Lcvette on topic Rapid and Cutting Feedrate
you can use the main velocity slider which will limit all motion to the velocity percentage calculated by the slider. this will limit all motion so that rapids and feed are limited to the same maximum.
- CNC_ANDI
23 Mar 2023 17:43 #267371
by CNC_ANDI
where i can find the main velocity slider?
- Lcvette
23 Mar 2023 17:50 #267372
by Lcvette
its the top slider in PB sliders column
- CNC_ANDI
26 Mar 2023 15:59 #267537
by CNC_ANDI
ah ok than i can configure my poti to the main velocity slider?
this will change rapid and cutting feedrate at the same time?
Moderators: KCJ, Lcvette
Time to create page: 0.123 seconds
