Rapid and Cutting Feedrate
26 Mar 2023 16:27 #267539 by Lcvette
Replied by Lcvette on topic Rapid and Cutting Feedrate
That will change the overall machining velocity of the system,  it is a hard ceiling,  and does not adjust anything independently it's a blanket adjustment.  So if your rapid is set at max system velocity, reducing the velocity side will immediately reduce your rapid, but will not effect the feedrate until it is adjusted below the federated setting.
You can load a program in the sim and play with it to get a feel of how it functions and see if this will work for your requirements.
Moderators: KCJ, Lcvette
Time to create page: 0.114 seconds
