M64 Connection to hal
29 Dec 2023 11:47 - 29 Dec 2023 15:00 #289321 by RIDO_JIMO
Replied by RIDO_JIMO on topic M64 Connection to hal
Mine starts at 5161.
I made a new one with all requirements
Last edit: 29 Dec 2023 15:00 by RIDO_JIMO.
29 Dec 2023 11:49 #289322 by RIDO_JIMO
Right, it makes sense. I will try it
02 Jan 2024 05:32 #289547 by RIDO_JIMO
Can you tell me which sequence PB should follow to assume that the Tool has been stored in the carousel? What is the step-by-step order to make that happen?
07 Jan 2024 11:36 #290120 by Lcvette
Replied by Lcvette on topic M64 Connection to hal
you can follow the toolchange.ngc flow and it states where the tool is recorded in the process, you can use a text editor to open the subroutine folder and have all files available to open side by side to see when the main subroutine toolchange.ngc calls the M10-M26 macros and the returns for each of those macros. that is the best way to get a working understanding of the tool change sequence and to edit/add/remove any things not pertinent to your machine setup.
The following user(s) said Thank You: RIDO_JIMO
10 Jan 2024 00:23 #290330 by RIDO_JIMO
Thank you! I made it!
Moderators: KCJ, Lcvette
Time to create page: 1.180 seconds
