- Thank you received: 19
Pommen makes a good point, this sounds like it could be your hal for the tool change type. have a look and maybe try comparing the configs from the ATC sim hal?Sadly not
To be honest I have no idea where to even look at this point.
For now I have gone back to manual tool changing which works without any problems.
But I really want to get the ATC working again since it worked perfectly fine with the old setup with the only drawback being that I had to manually change the pocket numbers when I changed out a tool in the ATC which wasn't very often since I had 24 pockets. But I assume that going back to an older Linuxcnc and probebasic version will be somewhat difficult as well since I don't know what exact version I was using.
