Probe Basic ATC Setup Problems
- spumco
- Thank you received: 896
03 Oct 2024 19:24 #311248
by spumco
Replied by spumco on topic Probe Basic ATC Setup Problems
It might be helpful to turn on debugging in terminal to see exactly what point in the sequence its getting stuck.
INI file
[DISPLAY]
DEBUG = 0x10
And then start LCNC from the terminal.
Attempt your tool change (M6 T1 or T1 M6) and when it gets hung up, use ALT-TAB to switch to the terminal window. You should be able to see what commands are going on in LCNC and likely a hint as to exactly what is hanging up.
INI file
[DISPLAY]
DEBUG = 0x10
- Lcvette
- Thank you received: 782
03 Oct 2024 22:21 #311255
by Lcvette
Replied by Lcvette on topic Probe Basic ATC Setup Problems
I agree with spumco, run in terminal so the debug messages show the failure point. Probably something simple I had 0 where an o word should have been that chased for 2 days troubleshooting.. probably started at it 50 times and that was with debug on telling me where the problem was
- Lcvette
03 Oct 2024 22:22 #311256
by Lcvette
Maybe post your toolchange sub also
- Martin.L
- Thank you received: 4
13 Sep 2025 13:23 #334922
by Martin.L
Replied by Martin.L on topic Probe Basic ATC Setup Problems
I reply into this because I had the same problem and solved it (thanks to Crish as always for the help) you probably are not calling tool prepared, or something iocontrol.x.tool related that "hangs" the toolchange
In my case was something like calling M64P7 with:
net ATC-pocket-reached motion.digital-out-07 iocontrol.0.tool-prepared
- Lcvette
26 Sep 2025 16:07 #335459
by Lcvette
happy to help and glad you got it sorted out!
Moderators: KCJ, Lcvette
Time to create page: 0.099 seconds
