Hello,
I have been using an old version of Probe Basic for a while but with a custom M6 tool-change macro and fixed pockets for each tool in the tool table.
That worked but wasn't very convenient so I updated to the current version of Probe Basic and tried to get it working. Most functions are already working fine but I am having trouble with the automatic tool changes. I modified the tool-change macros a little because my ATC hardware is set up differently but that should not affect the underlying logic (hopefully).
I have two Problems:
1. If I have a (manually loaded) tool in the spindle and use "M6" (without any tool number) then the machine deposits the tool in the first free pocket and it shows up in the UI, everything is fine.
But if I use "M6 T0" / "T0 M6" nothing happens.
If I use "M6 T1" / "T1 M6" (or any other tool number) nothing happens. As soon as I use any tool number in the command it doesn't work. Something seems to try and run as I can stop the execution but nothing ever happens. Interestingly, If the tool I requested is not in the tool table I get an error as expected.
I assume my changes to the tool-change and related subroutines are to blame but I find it strange that "M6" works fine while "M6 T0" doesn't.
2. The machine doesn't remember the tools in the ATC. If I manually load a tool into the spindle and use "M6" to store it in the carousel it shows up in the UI as it should but if I restart Linuxcnc the ATC is empty again. Only the tool in the spindle is being remembered.
To be fair, I don't quite understand what the prolog and epilog are doing either, maybe that's part of my problem.
Maybe someone can shed some light on the matter for me.
