Probe cancellation does not move the axes.
- Ismacr63
- Thank you received: 11
21 Sep 2024 16:08 - 21 Sep 2024 16:09 #310555
by Ismacr63
Probe cancellation does not move the axes. was created by Ismacr63
Hi, in probe basic when the 3d probe can't finish or I cancel it, the axes don't move until I bring the machine home.
Is there a way to not have to do homing so that the axes keep moving?
Last edit: 21 Sep 2024 16:09 by Ismacr63.
- Lcvette
- Thank you received: 783
26 Sep 2024 04:28 #310808
by Lcvette
Replied by Lcvette on topic Probe cancellation does not move the axes.
Are you changing back to manual mode to enable jogging? When it doesnt complete a subroutine it will be in auto mode.
The following user(s) said Thank You: Ismacr63
- spumco
- Thank you received: 905
26 Sep 2024 17:40 #310845
by spumco
Maybe not Probe Basic specific... but is there a way to force manual mode via the 'on_abort' process? So if any of the subroutines (probe, ATC, etc.) fails the machine jumps to manual mode.
If there is a way, that might be a nice-to-have addition to the PB config(s)... don't leave the machine hanging in an aborted auto mode.
Replied by spumco on topic Probe cancellation does not move the axes.
The following user(s) said Thank You: Ismacr63, Unlogic
- Ismacr63
26 Sep 2024 19:27 #310850
by Ismacr63
jog mode is activated.
Replied by Ismacr63 on topic Probe cancellation does not move the axes.
- spumco
26 Sep 2024 20:13 #310852
by spumco
"JOG" is not a mode. Even if the on-screen jog button is highlighted, LCNC can still be in MDI or Auto mode.
It looks like your screen has been edited to remove the mode indicator-buttons... or you've got a different version.
I've circled the mode buttons in the attached pic. You can also open halshow, and under 'halui' add the various mode indicators to the watch list to see what mode LCNC is in.
If, after a subroutine is aborted, LCNC is in Auto mode, you won't be able to jog regardless if the GUI's 'jog' button appears active.
- Ismacr63
26 Sep 2024 20:38 #310854
by Ismacr63
I don't know why those modes aren't shown in my version. I just downloaded it, followed the installation instructions and it looked like this.
How can I add them?
How can I add them?
- Unlogic
- Thank you received: 128
26 Sep 2024 21:11 #310857
by Unlogic
Replied by Unlogic on topic Probe cancellation does not move the axes.
That would be a great addition to Probe Basic.
- spumco
26 Sep 2024 23:28 #310861
by spumco
What Linux distribution are you using, and what version of LCNC? This might have a bearing - I've had problems in the past with certain combinations/versions of Debian/LCNC/qtpyvcp/PB. Seems like frequently some dependency or other invisible 'backstage' issue led to weird problems with PB.
I know it'll be a bit painful, but my suggestion is to make a copy of your config and then uninstall and reinstall PB using the instructions here:
forum.linuxcnc.org/qtpyvcp/53871-probe-b...on-start-here#310377
Sounds like something got messed up in your PB installation.I don't know why those modes aren't shown in my version. I just downloaded it, followed the installation instructions and it looked like this.
How can I add them?
- spumco
26 Sep 2024 23:32 #310862
by spumco
I'm not sure it can be done - but I'm no expert.
My initial thought is that the on_abort subroutine is run while LCNC is in auto mode... so there's no way for a program to switch to manual (or MDI) mode.
I'll dig around a little and open a new thread - the issue (or solution) may not be specific to PB.
That would be a great addition to Probe Basic.I'm not sure it can be done - but I'm no expert.
- Lcvette
27 Sep 2024 11:35 #310880
by Lcvette
you are not in full screen mode, hit F11 to allow the display to correctly fit the screen.
The following user(s) said Thank You: spumco, Ismacr63
Moderators: KCJ, Lcvette
Time to create page: 0.156 seconds
