Installing older version of ProbeBasic on buster and linuxcnc 2.8
2 years 3 weeks ago #311526 by FedX
Hi all,
i want to setup a virtual machine to test some functions.. My real machine is running with linuxcnc 2.8 and debian 10.
How do i install older releases of QtPyVCP, probeBasic and PyQt5Designer ? It seems all the newer versions are not running anymore because of python3 and all the docs i find is only for the newest versions.. I mean i can download older repositories but for QtPyVCP there is no installer where do i need to unpack it?
I don't want to change my machine to a newer OS yet..
2 years 3 weeks ago #311529 by Lcvette
Unfortunately it isnt available any longer because of python 2 be deprecated and supporting dependencies were no longer available. You only option is to update of you want to run probe basic.
2 years 3 weeks ago #311532 by FedX
How can that be? I don't need the neweset version of probeBasic i just want to use my own screen which i created with linuxCNC 2.8 and Buster.. I mean all the old versions must be available somwhere..
I know it's deprecated, but it would take ages to update all my customized GUIs and configurations and i don't want to change my machine and hardware..
2 years 3 weeks ago - 2 years 3 weeks ago #311536 by Lcvette
Ah, sorry assumed it was a PB install based on the topic header, you could git pull an older branch of qtpyvcp and compile from source maybe.
Last edit: 2 years 3 weeks ago by Lcvette.
2 years 3 weeks ago - 2 years 3 weeks ago #311549 by FedX
well kind of. I used probe basic as a basis for my own screen and changed the GUI to my needs. I saved all config and UI files.
But i struggle to install a compatible version of qtdesigner and QtPyVCP..
i installed python 2.7 and the basics:sudo apt update sudo apt install build-essential python2.7 python-setuptools git python-pip
now the qustion is which version of QtDesigner and QtPyVCP is compatible with buster and linuxCNC 2.8 and how to install it ?
found this script:  raw.githubusercontent.com/LinuxCNC/linux...igner/install_script
at least Qt5 designer works now.. But still struggling to get my UI
in ini i use DISPLAY = probe_basic and i copied my probe_basic folder with my configurations to usr/share/linuxcnc/probe_basic/ but it doesn't find the UI..
I also found a folder qtpyvcp in my backup directory. Am i missing something? I set it up some years ago and dont remember how..
Last edit: 2 years 3 weeks ago by FedX.
2 years 3 weeks ago #311564 by Lcvette
same here, been too long and too many other versions since to remember what would be needed. i would really not waste time with that though, ther newer version is much better. we give you two tabs to customize where the customized ui file lives in your config folder and is loaded at startup, so your changes and edits on those tabs will remain unchanged through updates etc. i would imagine you could remodel your build using that method and would be much happier, you will have the latest version foing forward, it is now installable via apt and you would likely spend less time doing that than solving how to install an old deprecated version with unsupported/unavailable dependencies.
Moderators: KCJ, Lcvette
Time to create page: 0.160 seconds
