Installing older version of ProbeBasic on buster and linuxcnc 2.8
2 years 3 weeks ago - 2 years 3 weeks ago #311645 by FedX
yes i saw the luncher, but it does not work.
I open the launcher for QtDesigner from the desktop, do some changes and save it . After that i launch probeBasic via the desktop shortcut and my changes show no effect..
The user Tab is nice but does not help me as i want to use my own screen..
Ok i reinstalled everything and now it seems to work as expected with the dev enviroment. Maybe the issue was that i installed it with root the first time
Last edit: 2 years 3 weeks ago by FedX.
2 years 3 weeks ago #311663 by Lcvette
just an fyi, if you want to run this on a machine that doesn't run the ui in a virtual environment, you will need to build a deb in order to install it on a different machine system.
2 years 3 weeks ago #311664 by FedX
thanks i'll check this. So far it seems to work by overwritng the .ui and .py files with the ones i made and run my machine config. I just need to change couple of things for saving my parameters as paramsaver is not working anymore.
Moderators: KCJ, Lcvette
Time to create page: 0.099 seconds
