Issues with migrating configuration from LCNC 2.8.3 buster to 2.9.3 bookworm
  • BaxEDM
  • BaxEDM's Avatar Topic Author
  • Junior Member
  • Junior Member
12 Oct 2024 14:34 #311871 by BaxEDM
I have a working configuration on LCNC 2.8.3 running on Buster. I would like to modernize so I'm trying to move to 2.9.3 bookworm. I figured I could just copy my existing configuration and run it, but that throws errors.
My configuration inserts a QtVCP window as additional tab in the Axis UI. Works great on 2.8.3. Now when I run that config on 2.9.3 I get two errors in separate windows. The first window is a QtVCP error window with the message:
  File "/usr/lib/python3/dist-packages/qtvcp/widgets/tab_widget.py", line 43, in tabSizeHint
    return QSize(size.width(), w)
TypeError: arguments did not match any overloaded call:
  QSize(): too many arguments
  QSize(w: int, h: int): argument 2 has unexpected type 'float'
  QSize(a0: QSize): argument 1 has unexpected type 'int'
The second window is the LinuxCNC log (attached as file), where the problem line seems to be:
[QTvcp.QTVCP.WIDGETS.SCREEN_OPTIONS][[36mINFO[0m]  [32mInstalling Embedded tab:BaxEDM, default, halcmd loadusr -Wn qtvcp_embed qtvcp -d -c qtvcp_embed -x {XID} baxedm2[0m (screen_options.py:461)
[QTvcp.QTVCP.WIDGETS.SCREEN_OPTIONS][[33mWARNING[0m]  problem inserting VCP 'BaxEDM' to location: rightTab :
 'VCPWindow' object has no attribute 'rightTab' (screen_options.py:485)
Any ideas how to resolve this?
  • BaxEDM
  • Junior Member
  • Junior Member
13 Oct 2024 10:42 - 13 Oct 2024 10:46 #311945 by BaxEDM
I installed the PyQt dev tools on this new 2.9.3 + bookworm PC and tried to open the *.ui file with the PyQt designer tool. It threw the same error. I can open this same ui file on my 2.8.3 + buster PC without any problems.
So something has changed in the toolchain that cannot deal with my "old" ui file.
In retrospect I should have started this tread in the PyQt section, but I cannot move it. If you are an admin, can you move it for me?
Last edit: 13 Oct 2024 10:46 by BaxEDM.
13 Oct 2024 12:07 #311955 by tommylight
There is no PyQT section, do you mean QTVCP or QTPyVCP?
  • BaxEDM
  • Junior Member
  • Junior Member
13 Oct 2024 17:43 #311995 by BaxEDM
QTPyVCP would be the best match.
13 Oct 2024 18:01 #311998 by tommylight
Moved, thank you.
  • BaxEDM
  • Junior Member
  • Junior Member
14 Oct 2024 17:37 #312079 by BaxEDM
I fixed it, but probably not in the easiest way. I completely rebuild my *.ui file with the designer, but used the designer on the new pc instead. Screens look the same, use the same widgets and now the UI runs.
Loading a *.ui made on a older version apparently is not backwards compatible...
After the ui finally loaded I ran into other issues. Took me a while to find what was causing that. Turned out my existing python user scripts refused to run. To fix that the first line in the *.py files needed to be changed from:
#!/usr/bin/env python
to
#!/usr/bin/env python3
also I changed the rights to the python files with chmod u+x
After that the scripts ran without any problems.
The following user(s) said Thank You: tommylight, Lcvette
Moderators: KCJ, Lcvette
Time to create page: 1.055 seconds
