Probe Basic do not start
13 Dec 2024 16:14 #316586 by Blume
Probe Basic do not start was created by Blume
i have some problems to convert my *ini and *hal file from QT-Dragon to Probe basic. Have some errors when i start it. I screenshot my CNC Folder.
i cant find the error. please help me that i can start it
13 Dec 2024 16:22 - 13 Dec 2024 16:23 #316589 by Lcvette
Replied by Lcvette on topic Probe Basic do not start
what error are you getting? need more information from your install also, without it we have no way to know what the issue could be.
Last edit: 13 Dec 2024 16:23 by Lcvette.
13 Dec 2024 16:28 - 13 Dec 2024 16:35 #316591 by Blume
Replied by Blume on topic Probe Basic do not start
sorry, i forgot the report file
I install the stable Version from PB. I follow the guide.
Don't know if this is the problem
emcMotionInit: emcTrajInit failed
emc/task/emctaskmain.cc 3054: can't initialize motion
or this part. But the feed override i copied from the guide.
INIFILE: ERR_CONVERSION, section=DISPLAY, tag=MAX_FEED_OVERRIDE, num=1, lineNo=15
Last edit: 13 Dec 2024 16:35 by Blume.
13 Dec 2024 16:56 - 13 Dec 2024 16:57 #316596 by Lcvette
6 decimal places only for settings in the ini file.. you have too many for max feedrate, better check the rest of the file also
Last edit: 13 Dec 2024 16:57 by Lcvette.
13 Dec 2024 17:40 #316599 by Blume
ok, thanks, i try it
15 Dec 2024 13:08 #316703 by Lcvette
did you get it sorted?
15 Dec 2024 14:23 - 15 Dec 2024 14:26 #316707 by Blume
Hi, changed my Config. I get an error with the path from this. But i attached a screenshoot with my folder.
FileNotFoundError: [Errno 2] Datei oder Verzeichnis nicht gefunden: 'user_tabs/
USER_TABS_PATH = user_tabs/             # REQUIRED Setting for Probe Basic
USER_BUTTONS_PATH = user_buttons/       # REQUIRED Setting for Probe Basic
Last edit: 15 Dec 2024 14:26 by Blume.
16 Dec 2024 08:49 #316732 by CNC_ANDI
Replied by CNC_ANDI on topic Probe Basic do not start
die fehlermeldung sagt dir doch genau was los ist... dir fehlen diese 2 ordner in deinem config ordner.... erstelle diese und fertig
16 Dec 2024 16:34 #316769 by Lcvette
Copy those folders from the sim per the docs
16 Dec 2024 19:19 - 16 Dec 2024 19:20 #316794 by Blume
Hi, my fault was that i copy the foldes from the folder /machine_setup_files
know i take the folders from the sim folder.
second step i delete all # REQUIRED Setting for Probe Basic in the ini file.
Know i get the start logo and a new error .
I think something goes wrong with my postgui.hal but i dont know what.
[qtpyvcp.app.launcher][[36mINFO[0m]  Loading POSTGUI_HALFILE: /home/cnc/linuxcnc/configs/Black_Phanter/postgui.hal (launcher.py:98)
not: already exists
/home/cnc/linuxcnc/configs/Black_Phanter/postgui.hal:5: waitpid failed /usr/bin/rtapi_app not
/home/cnc/linuxcnc/configs/Black_Phanter/postgui.hal:5: /usr/bin/rtapi_app exited without becoming ready
/home/cnc/linuxcnc/configs/Black_Phanter/postgui.hal:5: insmod for not failed, returned -1
Failed to load POSTGUI_HALFILE with error: 1
Last edit: 16 Dec 2024 19:20 by Blume.
Moderators: KCJ, Lcvette
Time to create page: 0.129 seconds
