Probe Basic Tool Setter questions
07 Feb 2025 22:46 #320963 by Lcvette
Replied by Lcvette on topic Probe Basic Tool Setter questions
Sorry it looks like it's maybe missing in the kernel build.
Restart and try running again
07 Feb 2025 22:50 #320964 by Lcvette
You can also open the synaptic manager and search:
linux-image
Right click the latest rt preempt signed kernel version and select for installation. Then click apply in the top menu. See if that works
07 Feb 2025 22:55 #320966 by CGT80
Replied by CGT80 on topic Probe Basic Tool Setter questions
What are the dependency names?
Is it the 4 listed at the end?:
linux-image-6.1.0-30-rt-amd64
linux-image-6.1.0-30-amd64
linux-image-amd64
linux-image-rt-amd64
I tried
chris@PM-833TV:~$ sudo apt install linux-image-6.1.0-30-rt-amd64
It came back with the same error and those 4 listed.
07 Feb 2025 23:08 #320968 by Lcvette
Which link did you use to build the iso?
07 Feb 2025 23:08 #320969 by CGT80
This is what I found: linux-image-6.1.0-30-rt-amd64
Linux 6.1 for 64-bit PCs, PREEMPT_RT (signed)
I clicked on mark for reinstallation and then clicked apply.
It came back with:
E: Internal Error, No file name for linux-image-6.1.0-30-rt-amd64:amd64
07 Feb 2025 23:10 #320970 by Lcvette
Ok, have you installed linuxcnc yet?
07 Feb 2025 23:14 #320971 by Lcvette
This may be easier to chat in real time
m.me/ch/AbY0S0wQv83WgA-x/
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
07 Feb 2025 23:26 #320973 by rodw
Replied by rodw on topic Probe Basic Tool Setter questions
People who follow random methods to install Linuxcnc are bound to  end up with issues sooner or later as things change
Install using the image on the downloads page and install probe basic etc from repositories
This will mean you get better support as people like Lcvette will be dealing with a known environment.
07 Feb 2025 23:31 #320974 by Lcvette
@rodw, I haven't checked recently, but the iso had an old qtpyvcp source listed that causes some issues and requires removed to resolve. We updated the instructions to use the lockdown deb on the forum page as it doesn't have the outdated source.
08 Feb 2025 11:39 #321009 by CGT80
In my case, I actually followed the directions and used the links that Lcvette listed, but it seems it was right around the time that changes were made to probe basic and I hadn't updated since then. There were also a few other changes I made while trying to get everything to work and also to get better latency numbers.
It wasn't a surprise that I needed to do the probe basic conversion again and although I didn't want to reload linux, I did tweak some things there and I had the same thought as Lcvette, when I had issues updating, in that it might be best to start over.
Even though Dr. Dflo did link to the proper instructions page that you guys use, I missed a step or it was updated since I followed it and with the struggles of learning it all, I may have caused some of the issues.
Lcvette spent a lot of time with me on messenger to chase down the issues. That turned out to be a great way to quickly share pictures of what I had going on.
I'm thankful he and everyone else on the forum have taken the time to help people get their machines going. I have read many threads on the forum and that helped me piece together hal ini and of course had lots of information on the hardware of converting a mill.
Moderators: KCJ, Lcvette
Time to create page: 0.506 seconds
