Probebasic tool length calculation
11 months 2 weeks ago #338565 by Lcvette
ok, i have a clean install of everything and have ran a test with a new tool and everything seems to be working as expected on the main branch.
I set my parameters as follows and ran the test with the below results:
spindle zero = 10.0000
load new tool = 221
click touch off current tool
manually trigger probe tip button on probe page at Z-8.0015
spindle retracts home position
tool length offset is stored in tool table as 1.9985
z axis dro shows -1.9985
all of this seems to track correctly. can you try running things in your sim to see if it behaves differently from your machine? it may show something or maybe not.
also can you post your tool_touch_off.ngc subroutine code so i can compare to what the sim has? everything in the code appears to be correct and here it is tracking correct.
my earlier findings seem to be related to the experimental branch i was working on and the issues are not present on the clean install.
Moderators: KCJ, Lcvette
Time to create page: 0.270 seconds
