(Solved) Probe Basic - HAL pins not being created
1 month 4 weeks ago #349255 by spumco
works fine!  how are you creating things?  are you opening using editvcp probe_basic and then opening the user ui?
No, I edited the user ui directly.  Sounds like that may be my problem.  I'll have another go at it and report back.
I'm on trixie, did a pull just a week or so ago so I should be up to date.
1 month 4 weeks ago #349258 by Lcvette
so the dro's were not really meant to be customized in that manner so they went last in the loading sequence using a timer to stop any conflicts during load, that being the case the hal widgets do not get registered for the dro ui's only for the usertab uis.. i will see if there is some magic i can do to include the dro's and post back when i have an answer on it!
1 month 4 weeks ago #349260 by spumco
Ok, HalLedIndicator is now showing up in halshow.
Every time I tried to edit probe_basic.ui I couldn't save it due to permissions.  And trying 'sudo editvcp probe_basic' resulted in an error before opening.
Had to
  • make a copy of probe_basic.ui and probe_basic.qrc
  • paste copy in some non-root folder
  • open sudo -thunar and rename the original
  • open the copy in vcp
  • open the user_tab.ui file and edit/save both ui files
  • using sudo-thunar paste the probe_basic.ui & .qrc file copies back in to the python3/dist-packages/probe_basic folder.
I suspect my earlier failure is that I didn't have probe_basic.ui open, or the right .qrc file in the right place.
The user tab is not showing up on the screen (see attached), but at least I've made some progress.
1 month 4 weeks ago #349262 by Lcvette
you should not be saving the probe basic ui file only the files from the config folder. however, the main probe basic ui must be opened first to load the qtpyvcp widgets correctly. you can open it but not save it, only save the config user files. each one must be saved and then close designer and reopen for the next that should avoid the call for the qrc file which is located in the usr/python3/probe_basic system wide directory. you really should never have to go into that for this work.
the dro ui's like i said above have a timer that prevents them currently from registering the hal widgets on initial startup. I was too tired to mess with it tonight, but will have aquick look in the morning to see if its something simple. i know i had to add the timer to prevent other issues i was dealing with from loading multiple ui files so i make no promises. you may need to add the led's to the sidebar tab or something which shouldn't have any issues as demonstrated previously above.
1 month 4 weeks ago - 1 month 4 weeks ago #349263 by spumco
I'm not worried about the DRO at this point - the widget rules are accomplishing what I want -  and I understand I'm working on an edge-case.
My intent now is to add LED's to the user sidebar tab, not circle back and mess with the DRO again.
I'll try it again without saving the probe_basic.ui file and see what happens.
EDIT
I just did an update/upgrade and managed to overwrite everything, since I was 'just fiddling around' I didn't bother making a copy of the PB config folder.  ARGH.
I'll have another go tomorrow.
Last edit: 1 month 4 weeks ago by spumco. Reason: Brainfade
1 month 4 weeks ago #349280 by Lcvette
doh.. yeah, that can happen...
I just pushed some changes that allow sequential loading correctly that captures hal loading for all ui's at startup for registration. this should allow the use of hal widgets in all user ui files. should be up and live by 8am EST.
Moderators: KCJ, Lcvette
Time to create page: 0.165 seconds
