(Solved) Probe Basic - HAL pins not being created
1 month 4 weeks ago #349244 by spumco
I don't have any of the qtpyvcp pins listed in any of my hal files - but they're still loading.
I get that connections to any of the qtpyvcp hal pins needs to be done in post-gui.hal.
Would you mind trying to create a qtpyvcp hal pin like I'm attempting and see if you can make it work?
I don't want to start fiddling with the main probe_basic.ui file, but you or one of the other devs might have some test configs to see if you all can figure out if this is just me or a bug.
1 month 4 weeks ago #349246 by Lcvette
ok i just tested and i see the test button i created in halshow, i can set and clr it to enable and disable it, it is under Pins/qtpyvcp/hal_test_button. sooo it is working here, not sure what you might be doing differently?
1 month 4 weeks ago #349247 by Lcvette
here it is working.. i did not change anything at all just dropped the halbutton widget in the usertab and gave it a pinbase name saved then started probe basic and everything was there!
1 month 4 weeks ago #349248 by spumco
Awesome, thanks!
Can you try a HalLedLight and see if it shows up too?  That'd confirm I'm off the rails somewhere.
1 month 4 weeks ago #349249 by Lcvette
works fine!  how are you creating things?  are you opening using editvcp probe_basic and then opening the user ui?
1 month 4 weeks ago #349250 by Lcvette
maybe try bringing over the latest user files, there have been some changes and some may no longer be up to date with the porting we did.  the testing i was using used the latest develop branch for the trixie debian 13 probe basic for reference, i do not have a bookworm machine at the momenht while im working on another project so cannot test there if that is what you are on. if so i would recommend updating to the trixie version
Moderators: KCJ, Lcvette
Time to create page: 0.119 seconds
