Qtvcp is missing on linuxcnc environment
07 Feb 2020 05:43 #156676 by prochj51
I wanted to build something with QTVCP and from what I have read
the module should be installed in folder /lib/python2.7/qtvcp/ .
But the whole folder is missing on the my linuxcnc environment.
I use linuxcnc-stretch-uspace-amd64. I even tried to locate qtvcp with
sudo updatedb
locate qtvcp
with no luck.
I am not aware of that I would have accidentally deleted it.
I would like to ask if you know where the problem is and how I should install it in addition?
Should I download the file qtvcp from the repository?
Jiri
07 Feb 2020 08:25 #156681 by bbsr_5a
Replied by bbsr_5a on topic Qtvcp is missing on linuxcnc environment
Hi
are you shure you want QTVCP
not QTPYVCP
this are different things
to get the new Screens you need qtpyvcp
there is a GIt for this to update
github.com/kcjengr/installer
07 Feb 2020 08:31 #156683 by prochj51
Replied by prochj51 on topic Qtvcp is missing on linuxcnc environment
This is what I want.
linuxcnc.org/docs/2.8/html/gui/qtvcp.html
it says qtvcp or am I getting it wrong?
07 Feb 2020 10:10 - 07 Feb 2020 10:11 #156690 by prochj51
Ok,
so I download the qtvcp from the repository and put into
correct place.
Then I followed the manual for including the widgets into a designer.
The plugin seems to be loaded
But now the problem is, that I cannot see the widgets in the widget box
on the left side of the designer.
Thank you very much for any ideas!
Jiri
Last edit: 07 Feb 2020 10:11 by prochj51.
07 Feb 2020 13:45 #156696 by cmorley
Replied by cmorley on topic Qtvcp is missing on linuxcnc environment
What version of linuxcnc are you using?
Qtvcp is available in 2.8 or master.
have you seen this README:
github.com/LinuxCNC/linuxcnc/tree/master...ython/qtvcp/designer
Chris
07 Feb 2020 13:45 #156697 by cmorley
Hi
not QTPYVCP
Qtvcp does screens too
07 Feb 2020 15:08 #156702 by prochj51
Okey,
so I have dowloaded .iso from this www.linuxcnc.org/testing-stretch-rtpreempt/ so I have 2.7 ..... where I can download 2.8 then? It says latest stable version is 2.7.15. Do I have to clone the master and build it?
But can't it also work on 2.7? I checked and I have all necessary libraries listed
in readme you sent and every module seems to be in correct folder.
Sorry maybe these are stupid questions but I am brand new to linuxcnc.
Thanks a lot. I appreciate it.
Jiri
07 Feb 2020 15:48 #156704 by persei8
Replied by persei8 on topic Qtvcp is missing on linuxcnc environment
qtvcp is included with the master branch distributions. To get the latest, check out buildbot.linuxcnc.org/ and follow the directions there. Since you have stretch, use the stretch package. Read the file that Chris mentioned as well as linuxcnc.org/docs/2.8/html/gui/qtvcp.html to get designer to work. One problem I had, (it may be fixed now, I don't know) is that I had to add the following to my .xsessionrc file:
export EMC2_HOME=/usr
if [ -d $HOME/.local/bin ]; then
export PATH="$HOME/.local/bin:$PATH"
fi
PS
Although the buildbot page says to use sudo apt-get install linuxcnc, it should be sudo apt-get install linuxcnc-uspace
HTH
07 Feb 2020 23:31 #156718 by cmorley
Sorry. no Qtvcp requires 2.8 or better to work.
I requires changes to other code in linuxcnc.
Chris
08 Feb 2020 07:39 #156745 by prochj51
Guys thanks a lot,
I will check it out.
Jiri
Time to create page: 2.309 seconds
