QT designer ImportError: No module named richtext_selector
- BeagleBrainz
- Visitor
29 Feb 2020 19:57 #158859
by BeagleBrainz
QT designer ImportError: No module named richtext_selector was created by BeagleBrainz
Hi Chris......another issue but this related to designer for qtvcp, bare with me I'm not really up to speed with using git so hopefully I've got it right.
I did a clone last night.
I did a git checkout 2.8
then a git pull
when I did the pull it had a message about the discussed change here forum.linuxcnc.org/38-general-linuxcnc-q...91-gadf1eff73#158846. (I'm thinking I maybe on the right track)
Linuxcnc Version 1:2.8.0~pre1.5480.gff35df86e
Could this file name be wrong qtvcp.widgets.richtext_selector import RichTextEditorDialog
There is a file in the git sources emc-dev/lib/python/qtvcp/widgets/richfont_selector
If I change line 10 in status_label_plugin.py from
to
designer loads fine.
qtvcp from the linuxcnc configurator screens load ok with the mod
then a git pull
murphy@ThinkPad-T530:~$ designer -qt=5
qt5ct: using qt5ct plugin
qt5ct: D-Bus global menu: no
[QtDesigner][INFO] Logging to "/home/rmurphy/qtdesigner.log" (logger.py:88)
File "/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/python/qtvcp_plugin.py", line 31, in <module>
from qtvcp.plugins.status_label_plugin import StatusLabelPlugin
File "/usr/lib/python2.7/dist-packages/qtvcp/plugins/status_label_plugin.py", line 10, in <module>
from qtvcp.widgets.richtext_selector import RichTextEditorDialog
libpng warning: iCCP: known incorrect sRGB profile
qt5ct: D-Bus system tray: noCould this file name be wrong qtvcp.widgets.richtext_selector import RichTextEditorDialog
from qtvcp.widgets.richtext_selector import RichTextEditorDialogto
from qtvcp.widgets.richfontselector import RichTextEditorDialogdesigner loads fine.
- Thank you received: 2181
29 Feb 2020 20:22 #158860
Replied by cmorley on topic QT designer ImportError: No module named richtext_selector
The errors don't show up on my test systems because the old files are still there - I'll figure out the right fix and push soon.
Thank You!
And thanks for the Mint work.
Chris
Thank You!
Chris
The following user(s) said Thank You: BeagleBrainz
29 Feb 2020 21:03 #158862
Pushed a fix - it'll take a while for debs to be built.
- BeagleBrainz
- Visitor
29 Feb 2020 21:47 #158867
by BeagleBrainz
Replied by BeagleBrainz on topic QT designer ImportError: No module named richtext_selector
Built on Mint-19.2 all good
Time to create page: 0.254 seconds
