Macro Tab.Widget
08 Apr 2020 13:21 #163222 by hottabich
Macro Tab.Widget was created by hottabich
There are several files like go_to_zero.ngc. Will I be able to implement their work with
using MacroTab? If possible, how?
08 Apr 2020 15:41 #163234 by cmorley
Replied by cmorley on topic Macro Tab.Widget
Yes most any macro file can work with microtabs.
There are some basic docs here:
linuxcnc.org/docs/2.8/html/gui/qtvcp_wid...tml#_macrotab_widget
If you have some that you think should be included, we can look at that.
Chris
08 Apr 2020 23:36 - 09 Apr 2020 02:39 #163298 by hottabich
Replied by hottabich on topic Macro Tab.Widget
I have three files: go_to_zero.ngc, go_to_home.ngc, auto_tool_zero.ngc.
I put it in the macros folder along the path home / jura / linuxcnc / nc_files / probe / basic_probe /macros. I create an OWord file there. I am at a loss with pictures. What am i doing wrong
please comment. Added by svg icon tab.
Last edit: 09 Apr 2020 02:39 by hottabich.
09 Apr 2020 05:52 #163314 by cmorley
So here is how to get one of your file to be found by the tab widget. Note the magic comments:
; MACROCOMMAND=
; MACRODEFAULTS=
; MACROIMAGE=go_to_zero
; will jog the machine to zero
o<go_to_zero> sub
 o<100> if [#5422 LT 0]
   G0 Z0
   G0 X0 Y0
 o<100> else if [#5422 GE 0]
   G0 X0 Y0
   G0 Z0
 o<100> endif
o<go_to_zero> endsub
M2
I see I need to work on the image displaying - the images are not scaled properly when I tested.
09 Apr 2020 08:06 - 09 Apr 2020 08:43 #163334 by hottabich
What size icon_tab.svg is needed? OWord first and second line must beat
empty? Sorry, but I don’t know English, but with google translate I understand
a lot less. I work purely by intuition. Thank you very much.
Last edit: 09 Apr 2020 08:43 by hottabich.
09 Apr 2020 08:28 #163341 by cmorley
The three lines are required so macroTab knows this is an oword designed for macroTab.
The first and second lines are empty because your oword does not require input.
The icon is supposed to scale to size but that seems to be a bug.
09 Apr 2020 08:29 #163342 by cmorley
Here is a sample that require input:
; MACROCOMMAND=xinc,yinc,zinc
; MACRODEFAULTS=0,0,0
; MACROIMAGE=test-tool
O<go_to_position> sub
G17
G20
G54
G61
G40
G49
G80
G90
;#1 = <X-Pos>
;#2 = <Y-Pos>
;#3 = <Z-Pos>
(DBG, Will now move machine to X = #1 , Y = #2 , Z = #3)
G0 X #1 Y #2 Z #3
O<go_to_position> endsub
M2
09 Apr 2020 08:31 #163343 by cmorley
That sample would be saved as go_to_position.ngc
09 Apr 2020 08:46 - 09 Apr 2020 09:06 #163349 by hottabich
That's right? Or so.
Last edit: 09 Apr 2020 09:06 by hottabich.
09 Apr 2020 09:14 #163353 by cmorley
Try this:
I converted the images to png files
Time to create page: 1.161 seconds
