qtdragon pins?
21 Oct 2021 19:55 #223861 by cmorley
Replied by cmorley on topic qtdragon pins?
then you are using Jim's
22 Oct 2021 01:04 #223878 by ikkuh
Replied by ikkuh on topic qtdragon pins?
Very confusing this. I use LinuxCNC pre 2.9 from buildbot. You mean to say that has the github.com/persei802/QtDragon_hd version?
22 Oct 2021 01:10 #223879 by cmorley
I''ll I can really say is linuxcnc's version doesn't search for that text.
If I you run linuxcnc from the terminal it will tell you where it found the files from.
I bet it's finding some local files rather then the default linuxcnc's files.
The following user(s) said Thank You: ikkuh
22 Oct 2021 01:13 #223881 by ikkuh
Will be at the machine in a few hours, will check then. Thanks again for your support.
22 Oct 2021 06:27 - 22 Oct 2021 06:28 #223905 by ikkuh
the editor for this forum sucks big time. Can not insert quotes or code without it turning into a mess.
Can not even post the output from LinuxCNC starting because there are too many links in it, well there are exactly 0 links in it.
In attachment the output from LinuxCNC starting up on my machine.
Last edit: 22 Oct 2021 06:28 by ikkuh.
  • Moderator
  • Moderator
22 Oct 2021 08:16 #223917 by tommylight
Replied by tommylight on topic qtdragon pins?
Click on "source" on the upper left of the editor, much better with that.
22 Oct 2021 08:20 #223919 by ikkuh
I do that all the time. But as soon as I use a [code] or something like that everything screws up and all the end [/] codes end up at the end of the text.
  • Moderator
  • Moderator
22 Oct 2021 10:13 #223925 by tommylight
Yes it does, and for the life of me i can not figure out why someone somewhere thought that it a usable editor and pushed it upon us humans! :)
22 Oct 2021 12:47 #223934 by cmorley
linuxcnc master version (2.9) has an older version of qtdragon_hd as well as the original qtdragon.
Both of these differ slightly from Jim's versions.
This shows the two versions - with different color styles:
linuxcnc.org/docs/devel/html/gui/qtdragon.html#_introduction
by the way using control V works better then the mouse for coping in the forum. - it sucks for sure
23 Oct 2021 09:39 #223992 by ikkuh
I see that the qtdragonhd_ pins are gone. Very nice, thanks
Component Pins:
Owner Type Dir Value Name
58 bit OUT FALSE qtdragon.btn-laser-on
58 float OUT 0 qtdragon.cam-rotation
58 bit OUT FALSE qtdragon.eoffset-clear
58 s32 OUT 0 qtdragon.eoffset-count
58 bit OUT FALSE qtdragon.eoffset-enable
58 float IN 0 qtdragon.eoffset-value
58 bit IN FALSE qtdragon.led-limits-tripped
58 bit IN FALSE qtdragon.led-probe
58 float OUT 720 qtdragon.slider-jogspeed-angular
58 float OUT 360 qtdragon.slider-jogspeed-linear
58 float OUT 100 qtdragon.slider-override-feed
58 float OUT 2500.2 qtdragon.slider-override-maxv
58 float OUT 100 qtdragon.slider-override-rapid
58 float OUT 100 qtdragon.slider-override-spindle
58 float IN 0 qtdragon.spindle-amps
58 u32 IN 0x00000000 qtdragon.spindle-fault
58 bit OUT FALSE qtdragon.spindle-inhibit
58 u32 IN 0x00000000 qtdragon.spindle-modbus-errors
58 float IN 0 qtdragon.spindle-volts
Time to create page: 0.401 seconds
